Mr. Mann Posted July 12, 2007 Share Posted July 12, 2007 I've got a floor plan with multiple stairs that are the same. I thought that I could create the stair using the tool and just copy (option drag) it to the locations where it is needed. When I've come back to edit the stair it has all sorts of problems. Why is this a problem? Quote Link to comment
digitalcarbon Posted July 13, 2007 Share Posted July 13, 2007 i do not know but just make a new stair with the stair tool. this happened to me last week. Quote Link to comment
ptarmigan Posted July 13, 2007 Share Posted July 13, 2007 About stairs .. Take a stair with flights 800 wide. Add a u-landing to be 1000 deep, so change side 1 and side 3 to 1000. In the middle of this new landing is an indent where the landing width is 800. Is the workaround for this just to make your own little bit of 3-d landing and stuff it into the indent ? BTW, if one changes start and end lengths to half the width of the u-landing, the flights become misaligned. Is there something I can do in the stair-tool ? ptarmigan Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted July 13, 2007 Vectorworks, Inc Employee Share Posted July 13, 2007 What version of VectorWorks are you running? Quote Link to comment
Mr. Mann Posted July 13, 2007 Author Share Posted July 13, 2007 Just updated to 12.5.2 hoping that would help, but it only compounded the problem. After the update placing a stair caused the program to crash twice. Each time I had to re-enter the serial # and related info. This may have been related to memory --I have a lot going today. I ended up throwing in the stairs with the 2d tools to make a deadline. -Scott Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted July 16, 2007 Vectorworks, Inc Employee Share Posted July 16, 2007 OK, the reason you're still having problems is that you need to actually run a script to clear the "corruption" created by the earlier version of the plug-in. Once you do that, the plug-in will work properly for all your new and existing stairs. This script will do it: {Fix Stair Associations script BEGIN} PROCEDURE FixStairAssociations; CONST kOnDeleteDelete = 4; {Target object is deleted when owner is deleted.} kOnDeleteReset = 5; {Target object is reset when owner is deleted.} VAR stairs :DYNARRAY of HANDLE; stairCnt :INTEGER; cnt1, cnt2 :INTEGER; boo :BOOLEAN; procedure FindStairObjects(h :HANDLE); BEGIN stairCnt := stairCnt + 1; ALLOCATE stairs [1..stairCnt]; stairs[stairCnt] := h; END; procedure FindUpperStairsToDelete(h :HANDLE); VAR str :STRING; BEGIN str := GetRField(h, 'Stair', 'UUID'); if Copy(str, 1, 1) = 'U' then BEGIN stairCnt := stairCnt + 1; ALLOCATE stairs [1..stairCnt]; stairs[stairCnt] := h; end else BEGIN SetRField(h, 'Stair', 'HeightByLayer', 'FALSE'); SetRField(h, 'Stair', 'UUID', ''); SetName(h, ''); END; END; BEGIN stairCnt := 0; ForEachObject(FindStairObjects, (R IN ['Stair'])); for cnt1 := 1 to stairCnt do BEGIN for cnt2 := 1 to stairCnt do BEGIN boo := RemoveAssociation(stairs[cnt1], kOnDeleteDelete, stairs[cnt2]); boo := RemoveAssociation(stairs[cnt1], kOnDeleteReset, stairs[cnt2]); END; END; stairCnt := 0; ForEachObject(FindUpperStairsToDelete, (R IN ['Stair'])); for cnt1 := 1 to stairCnt DO DelObject(stairs[cnt1]); END; run(FixStairAssociations); {Fix Stair Associations script END} Quote Link to comment
willofmaine Posted September 2, 2007 Share Posted September 2, 2007 I just duplicated a stair, and changed the floor settings. The original stair reduced itself to a zero width, and the copy, at the other floors, had no upper representation. When I tried to delete the original stair, VW crashed. I tried to run the above script, but just got lots of errors. I copied it into a .txt file, and then used Tools/Scripts/Run VectorScript. Is this not the correct procedure?... The stair was originally created in 12.5.1; I'm now using 12.5.2. Thanks, Will Quote Link to comment
willofmaine Posted September 2, 2007 Share Posted September 2, 2007 So I tried creating this as a script in the resource browser, and I think it ran. I think it helped, in that it seems, ultimately, I can duplicate stairs to other locations and/or floors and get their representations to be as expected. However... Their floor associations seem to need to be reset many times before they finally understand which floors they're associated with. Also, it seems running the script in a file that already has stairs 'flattens' all of the stairs (it eems to disassociate them from their floors and send them to the lowest design layer...). Are scripts file specific, such that this one to fix (or that might fix...) the stair tool needs to be run in all files where a fix is desired? Thanks, Will Quote Link to comment
patrickhubble Posted October 10, 2007 Share Posted October 10, 2007 Ok, Sorry to ressurect this topic - but I have just run the script and the stairs still act strangely (ie, copy and move a stair in ground, and it moves in 1st floor as well, but it moves the original not the copy, so you end up with never being able to do a simple 3 storey fire escape stair). I'm using VW 12.5.1. The script seems to disconnect the stairs from the layer levels - which is fine. But copying the stairs after associating them with layer levels ends with the same result (ie. stairs are moved around on other levels but deletes other stairs made prior etc.) This issue has obviously been encountered by various users before - and i ask this, How does anyone do 3 fire escapes in a 3 storey building using the stair tool? (In actual fact, this is in preparation for our large building, 6 stories with 4 fire escapes, and I don't want to keep entering the same info 24 times when I change the stairs!) Quote Link to comment
mike m oz Posted October 10, 2007 Share Posted October 10, 2007 Make one stair and turn it into a symbol. Don't associate it with the layer levels. Quote Link to comment
islandmon Posted October 10, 2007 Share Posted October 10, 2007 Perhaps you're using the SlumLord version of the Stair Tool... it only creates the stairs and fire escapes on the first storey of a 3 storey building. To verify your version... look for the OIP check-box labeled "Pay-off to Fire Marshall". Quote Link to comment
patrickhubble Posted October 11, 2007 Share Posted October 11, 2007 Thanks guys, There's great potential here with the stair tool - if it could properly work linked to layer levels then this is one step towards a more parametric vectorworks. (And plus, stairs have always been difficult to get our head around them, and a tool like this is ideal if it works). Anyway, will just use it in a 2D sense for now. Quote Link to comment
