If you setup Benchmark Elevation markers in the annotation of a viewport - and set them to Control Point with a Y-Axis (2D MODE) - the reference point seems to be referenced to the position on the page rather than relative to the annotations. This means if you move your viewport - as one often does when setting up sheets - all the elevation benchmarks become incorrect as the the control point does not move with the viewport. The control point should bn "In" the annotations - and move along with the viewport.
This is close to a bug in my opinion - as there is not a single use case I can think of that would benefit from this behavior.
Tom Klaber
16 answers to this question
