Projector angles
3 minutes ago, Kevin Allen said:
Not if that projector is a hybrid symbol, I do not think, but if it's 3D only, should be fine.
So therefore you might choose to dupe the symbol, delete the 2d representation, rotate to suit, re-autohybrid if desired, et voila!
Thanks Andy and Sam! ProjectionViz 2 will rotate the projector to the tilt and generate the hybrid Top/Plan view. It will also let you choose the floor plane for visualizing the projector cone (as well as correctly displaying key stoning and lens shift). The Video Screen tool is going to give you a lot more options for showing the details of the projector mount and screen, while ProjectionViz is more targeted towards planning and visualization. It is currently Braceworks but not ConenctCAD compatible.
https://benghiatlighting.com/software/product/projectionviz-2/#description
