2,024 -
Everything posted by JBenghiat
To create a VP, call CreateVP() and use object variables to set as section: https://developer.vectorworks.net/index.php?title=VS:CreateVP https://developer.vectorworks.net/index.php?title=VS:Function_Reference_Appendix_G#Viewports However, creating a section VP via VS doesn't seem possible // Viewport type selectors // -------------- const short ovViewportProjectionType = 1000; // short read/write - the viewport projection type. - Public for VS const short ovViewportRenderType = 1001; // short read/write - the viewport render type. - Public for VS const short ovViewportPerspectiveDistance = 1002; // real read/write - the viewport perspective distance (used with custom perspective). - Public for VS const short ovViewportScale = 1003; // real read/write - the viewport scale. - Public for VS const short ovViewportDirty = 1004; // Boolean read/write - the viewport out-of-date (dirty) state. - Public for VS const short ovViewportProject2D = 1005; // Boolean read/write - the viewport project 2D state. - Public for VS const short ovViewportRenderBackground = 1006; // Sint32 read/write - the viewport render background. - Public for VS const short ovViewportViewType = 1007; // short read/write - the viewport view type. - Public for VS const short ovViewportLineWeightScale = 1008; // double read/write - the viewport line weight scale. - Public for VS const short ovViewportArrowheadScale = 1009; // double read/write - the viewport arrowhead scale. - Public for VS const short ovViewportDashedLineScale = 1010; // double read/write - the viewport dashed line length/spacing scale. - Public for VS const short ovViewportHatchLineScale = 1011; // double read/write - the viewport hatch line spacing scale. - Public for VS const short ovViewportDesignTextScale = 1012; // double read/write - the viewport design layer referenced text size scale. - Public for VS const short ovViewportSlashThicknessScale = 1013; // double read/write - the viewport slash thcikness scale. - Public for VS const short ovViewportAmbientIsOn = 1014; // Boolean read/write - the viewport ambient light is ON or OFF. - Public for VS const short ovViewportAmbientBrightness = 1015; // double read/write - the viewport ambient light brightness. - Public for VS const short ovViewportAmbientColor = 1016; // WorldPt3 read/write - the viewport ambient light color. - Public for VS const short ovSetDesignLayerVisibilityInAllViewports = 1017; // short, -1 = invisible, 0 = normal, 2 = grayed - Public for VS const short ovSetClassVisibilityInAllViewports = 1018; // short, -1 = invisible, 0 = normal, 2 = grayed - Public for VS const short ovViewportHDRIBackground = 1019; // Sint32 read only - the background for environment lighting - Public for VS const short ovSectionVP2DAttributeClass = 1020; // Sint32 read only - the RefNumber of the class responsible for attributes of overall cross-section or just the x-section of structural elements. - Public for VS const short ovSectionVP2DOtherAttribClass = 1021; // Sint32 read only - the RefNumber of the class responsible for attributes of cross-section generated from non-structural elements - Public for VS const short ovSectionVP3DFillStyleClass = 1022; // Sint32 read only - the RefNumber of the class reposnsible for fill style of the objects beyond section plane - Public for VS const short ovSectionVP3DLineStyleClass = 1023; // Sint32 read only - the RefNumber of the class responsible for line style of the objects beyond section plane - Public for VS const short ovViewportXPosition = 1024; // double read only - the X coordinate of the viewport on the sheet layer - Public for VS const short ovViewportYPosition = 1025; // double read only - the Y coordinate of the viewport on the sheet layer - Public for VS const short ovViewportAngleWithXAxis = 1026; // double read only - the angle that the viewport subtends with the X axis on the sheet layer in degrees - Public for VS const short ovViewportShowWallComponents_OBSOLETE = 1027; const short ovViewportGrayTransparent = 1028; // Boolean read/write - the viewport renders gray layers transparent - Public for VS const short ovViewportFlipText = 1029; // Boolean read/write - the viewport/dlvp adjusts for flipped text - Public for VS const short ovViewportBlackAndWhite = 1030; // Boolean read/write - the viewport/dlvp draws in black and white only - Public for VS const short ovViewportUseDocumentClassVis = 1031; // Boolean read/write - set/reads the Use Document Class visibilities settings for dlvps - Public for VS const short ovViewportDescription = 1032; // TXString read/write - a description for the viewport, which corresponds to the Dwg Title field for a corresponding Drawing Label. - Public for VS const short ovViewportLocator = 1033; // TXString read/write - the locator for the viewport, which corresponds to the Item field for a corresponding Drawing Label. - Public for VS const short ovViewportIsLinked = 1034; // Boolean read - indicates whether the viewport is a linked viewport const short ovViewportDisplayPlanar = 1035; // Boolean read/write - the flag to indicate if planar and 2D objects are to be displayed const short ovViewportForegroundRenderType = 1036; // short read/write - the viewport render type. - Public for VS const short ovViewportHasCamera = 1037; // Boolean read only - whether there is a camera attached to the viewport or not const short ovCameraAttachedToViewport = 1038; // Boolean read only - whether the camera is attached to a viewport or not const short ovViewportCropVisible = 1039; // Boolean read/write - get/set the Crop Visible state of a viewport - Public for VS const short ovViewportLayerHeightIgnored = 1040; // Boolean read only - whether the viewport ignored layer height for single layer case const short ovViewportLightingDevice = 1041; // read/write - make an association between a lighting device light and an overriden light object for the viewport. const short ovViewportRePositionDimensionText = 1042; // Boolean read/write - the viewport/dlvp re-positions dimension text to other side of dimension line - Public for VS const short ovIsDesignLayerSectionViewport = 1043; // Boolean read only - indicates whether the linked viewport is a sheet layer or a design layer viewport - Public fo VS const short ovFDLSVPHiddenLineInWireframe_OBSOLETE = 1044; const short ovViewportPageSymbolScale = 1045; // double read/write - the viewport page symbol scale. - Public for VS const short ovViewportNavigateToFromSectMarker = 1046; // Boolean write only - selects the viewport and makes it visible - Not for public use const short ovViewportDetailLevel = 1047; // short read/write - low detail = 0, medium detail = 1, high detail = 2 - Public for VS const short ovViewportIsHorizontalSection = 1048; // Boolean read - indicates whether the viewport is horizontal section const short ovViewportTransformMatrix = 1049; // TransformMatrix read/write const short ovViewportViewMatrix = 1050; // TransformMatrix read/write const short ovViewportOperatingTransform = 1051; // TransformMatrix read const short ovViewportUnscaledBoundsWithoutAnnotations = 1052; // WorldRect read const short ovViewportResetForOnlyAnnotationsChange = 1053; // void write const short ovIsSectionViewport = 1054; // Boolean read only - indicates whether the viewport is a section viewport - Public for VS const short ovSheetLayerSectionViewportViewMatrix = 1055; // TransformMatrix read const short ovSectionViewportSectionViewMatrix = 1056; // TransformMatrix read/write const short ovViewportAttachDefaultRenderOptions = 1057; // Boolean(ignored) write const short ovViewportAttachDefaultCustomRenderWorksRenderOptions = 1058; // Boolean(ignored) write const short ovViewportDisplay2DComponents = 1059; // Boolean read/write const short ovViewportHiddenLineDisplay2DFills = 1060; // Boolean read/write const short ovViewportAttachDefaultLightingOptions = 1061; // void write const short ovViewportCreateDefaultEditableGroups = 1062; // void write const short ovViewportPrivateLayer = 1063; // MCObjectHandle read const short ovSectionViewportDisplayObjectsBeyondCutPlane = 1064; // Boolean read/write const short ovSectionViewportDisplayObjectsBeforeCutPlane = 1065; // Boolean read/write const short ovViewportHiddenLineDisplay2DFillsAllowed = 1066; // Boolean read const short ovSectionViewportCastShadowsFromRemovedPortion = 1077; // Boolean read/write const short ovSectionViewport2DResultsMerged = 1078; // Boolean read/write const short ovSectionViewport2DAttributesUseClass = 1079; // Boolean read/write - must be set true before you set class with ovSectionViewport2DAttributesClass const short ovSectionViewport2DAttributesClass = 1080; // RefNumber read/write const short ovSectionViewport2DOtherAttribsUseClass = 1081; // Boolean read/write - must be set true before you set class with ovSectionViewport2DOtherAttribsClass const short ovSectionViewport2DOtherAttribsClass = 1082; // RefNumber read/write
Is there a custom user origin? I can't remember off the top of my head, but a number of functions always use the internal origin. You need to get the user origin and offer your coordinates by that amount. You may also have to take rotated plan into account.
You could always create a new pop-up parameter in Spotlight Preferences. If you wanted data to auto-enter from the symbol, attach a custom record to the symbol definition, add a field matching the name of your user field, and add the record via Additional Default Records in Spotlight Preferences.
- 1 reply
- 1
Vectorworks has never had this feature. Are you thinking of the Autoplot Rotate Each commands?
You said you were able to create a PIO with parameter in the OIP. Place this line in the script of the PIO: Symbol('symbolName', 0, 0, 0); This will place the symbol symbolName at the center of the PIO, facing up.
I did some experimenting with this a few weeks ago, and there's no easy solution. If you have Lightwright, you can merge in CSV data, keying by channel, and then sync that data with Spotlight. LW handled a patch csv from Eos as expected, without any file cleaning.
It's been a couple years since I experimented, but when I last checked, they way Data Tags copy objects from their profile group (where layout objects are stored) to the object didn't work with PIO's. If I remember correctly, it basically gets converted to group before it gets copied.
The symbol insertion code is a one liner: https://developer.vectorworks.net/index.php?title=VS:Symbol You would ultimately want to do some error checks to make sure the named object exists and is of type symbol definition.
@spettitt are you just looking for the label to adopt the class of the rigging object it’s attached to? If so, I think this would be a fairly straightforward feature to add to Savvy Position Labels.
You seem to be describing a Plug In Object. PIOs will create their own insertion tool, with the interface for a point PIO being very similar to the symbol insertion tool. The script component for a simple PIO should draw the elements you want to display, with the origin of the scripted elements being the insertion point of the object (like a symbol definition). Your script can insert a symbol at the origin. You can also code all the geometry of the elements you want to draw, and it will appear symbol-like to the user.
If it’s for a document-wide setting, you don’t have to attach the record to anything— just use the default field values to store your data. You can get a handle to a record definition by its name.
Seconding Pat's suggestion. Create symbols instead of viewports. Once you're ready to start assigning control data, Convert to group (this is a named command, not to be confused with Group to Ungroup). You can think of a viewport as a smart photocopy -- a way to duplicate a drawing element for presentation or to show an alternate position.
The double underscore will hide a field. To hide a record, use SetObjectVariableBoolean on the record format with the selector 900. (True is hidden). Usually I check if the record exists, if not, create it, then hide. The record otherwise functions as usual, and you can create a script to toggle visibility as you're testing.
Files definitely do not have unique id’s. In fact, I think that’s a feature— if you were to save a backup or a named version, you would want the file to be identified the same. Storing a UUID in a hidden record would be the way to go, but you would need some kind of manual connection setup between the file and database.
You’re creating a bundle, though you may also want to start with the EmptyModule or TesterModule component example and build from there. Last time I tired, I still needed to change some project and build settings to get things to compile and run, but that was a while — I have custom xconfig files adapted to my development file structure and flow. I’ve recently started migrating to a cmake workflow. After getting past the learning curve, setting up new projects, supporting multiple Vectorworks versions, and working cross platform has become much easier.
You still need to define the object being extruded, so don't omit the BeginPoly/EndPoly calls GetCustomObjectPath works on Plug-in objects -- that won't get the extrude base, as an extrude is a native object type. Use OffsetPoly after EndPoly and before EndXtrd.
If this is part of a PIO, use BeginXtrd/EndXtrd instead of HExtrude.
I think want to use AddPoint() or Add2DVertex() in your polygon. Also make sure to call SetPolyClosed() to ensure it is a closed object and can extrude. By your screen shot, it looks open. Using DoMenuText calls in code that also uses handles can be problematic and is definitely not reliable in a PIO.
Script to isolate or select outermost line work
JBenghiat replied to unearthed's topic in Vectorscript
Have you tried the outer boundary mode of the polygon tool? Otherwise, you’re interested in a concave hull algorithm. You may be able to find some existing python examples, but I don’t think you’ll find a simple code snippet that someone can provide. -
Not entirely sure what you’re describing. Tools>plugins>run script will run a text file as a script You can also create a script in the Resource Manager and run from a script palette. It saves with the file, not as a plug-in.
Short answer -- no. The clip club is just essentially a view. The criteria is actually looking at a visibility flag that's set on objects (which really dates from pre-viewport days) and their containers (i.e. whether their containing layer is set to visible). Your worksheet isn't going to change if you're zoomed in on a group of objects, for example. The Clip Cube doesn't change any visibility flags, it just filters what gets displayed on screen. From a script standpoint, you could retrieve the clip cube, get its location and dimensions, then parse objects and test if they exist within the cube -- but that is not a small task.
Yes, sorry, I was going purely on memory. vs.Move3DObj() is the call. https://developer.vectorworks.net/index.php?title=VS:Move3DObj If you're not familiar with the concept oh handles, you can find a few threads here and on the Vectorscript forum. You would get the handle to the symbol with vs.LNewObj() and then pass that to the move command.
You need to use HMove3D() to set the height after inserting the symbol
No, not in Vectorscript
Thanks Andy and Sam! ProjectionViz 2 will rotate the projector to the tilt and generate the hybrid Top/Plan view. It will also let you choose the floor plane for visualizing the projector cone (as well as correctly displaying key stoning and lens shift). The Video Screen tool is going to give you a lot more options for showing the details of the projector mount and screen, while ProjectionViz is more targeted towards planning and visualization. It is currently Braceworks but not ConenctCAD compatible. https://benghiatlighting.com/software/product/projectionviz-2/#description
