filip Posted January 28 Share Posted January 28 Dear enthousiasts I can't export my vw model to fbx, the exported file contains only 0 bites, so It remains empty. On my other master computer the fbx export button remains gray, and exporting to fbx is not possible at all. Are there special settings needed or maybe a special workflow for doing this? regards Filip Bosscher Quote Link to comment
VIRTUALENVIRONS Posted January 28 Share Posted January 28 Try this, but use a duplicate copy. Covert your entire model to 3D polygons and then Export FBX. Quote Link to comment
Pat Stanford Posted January 28 Share Posted January 28 Or even better, what happens in a new blank file with just a single Extude? Have you restarted VW? Have you restarted the computer? Quote Link to comment
zoomer Posted January 28 Share Posted January 28 51 minutes ago, filip said: I can't export my vw model to fbx, the exported file contains only 0 bites, so It remains empty. Which VW Version ? I had this some years ago. AFAIR that happens when the file reaches a certain complexity. Smaller projects worked. 1 Quote Link to comment
filip Posted January 28 Author Share Posted January 28 @ VIRTUALENVIRONS: I will try this, thanks; do you know how to convert the 3d model to 3d polygons? @ Pat Stanford, I try this also, yes and yes, the computer and the program where restarted. @ zoomer: that might be a point, this is a rather difficult project and a big file, I don't know if that is complex for VW? Filip Bosscher Quote Link to comment
VIRTUALENVIRONS Posted January 28 Share Posted January 28 Under the Modify menu, Convert>Convert to 3D polys. Remember to use a duplicate copy Quote Link to comment
bjoerka Posted January 29 Share Posted January 29 In 2024 this works very well event with complex projects. Last week i did something that resulted in a 1.5gb fbx which worked well in Maya after importing. So maybe it´s related to the vwx version. I rember having problems in 2022 with large projects. 2 Quote Link to comment
filip Posted January 29 Author Share Posted January 29 Thanks for your advices; I tried all of them, but it didn't work. I tried exporting the vw into other 3d formats, like 3ds, kml, igs, sat, stl and stp it worked fine. Could it be that fbx needs some special settings? regards Filip Quote Link to comment
