In VW2023 I can right-click on an object on an inactive design layer + select 'Force Select' from the Object Context menu to select that object + make that layer active. In VW2024 I can no longer do this. 'Force Select' is there in the Object Context menu in my workspace, it just doesn't appear as an option when I right-click on an object. The only way it works is if the object I'm trying to force select is coincident with another object which is on the active layer + the active layer is stacked below the layer the object I'm trying to force select is on (!).
The same applies to the 'Activate Layer' + 'Activate Class' commands.
Is this a bug or have is there some obscure setting somewhere I've changed that's causing this behaviour?
Tom W.
12 answers to this question
