  • 11
Reports able to span 2 pages
Joe Golden ENT
12 answers to this question
Worksheet "pagination" is on the roadmap under "Active Research". Although it's been on there since at least April 2019 when I referred to it here.
I really hope this gets some more attention soon because the current worksheets are incredibly difficult to work with due to this and a few other simple things such as how difficult they are to format.
  • Like 3
9 minutes ago, Stephan Moenninghoff said:
anything in particular you need?
- Split across pages
- Functionality/control to have certain rows/database headers etc repeat on each page
- Ability to place logos/images/data/properties in headers/footers and within the worksheet
- Formatting bar rather than pop up formatting
In a dream world, database rows would work more like a proper database reporting engine:
- Group headers (large flat table splits in to multiple table chunks based on the data - i.e. Group By Field x)
- Hierarchical group headers - group on X field, then group on X field.
  • Like 4
By the way,
I have difficulties to set borders : if I want to remove the down border of a cell, sometimes it does not work. I have to select the cell below and remove the up border.
For big worksheet, it drives me crazy.
Also I saw that even if I have unchecked the “Auto-recalc” option, the functionality is still enable, if you make a Copy/Paste of on or multiple cell(s), or if you make a «Clear Contents»,  the worksheet is recalculated whereas the option is unchecked.
Again, it drives me crazy for big worksheet with many calculation within, I don’t want to spend hours waiting in front of my computer…
I think the way to make the calculation of values (searching into the drawing) has to be optimised, it takes several minutes for a surfaces worksheet on my Macbook Pro M2 MAX… that’s not normal.
Direct access to format functionalities would be a huge amount of time gain (without having to open a pop-up window).
Worksheets are really one of the better functionality of Vectorworks. But their ergonomics have 30 years old…
Edited by GatRed
I wrote a plug-in a while back that can split up a worksheet into multiple parts.  On normal worksheets, all of the data in the created worksheets are referenced back to the original worksheet so they will all stay up to date (on recalculation anyway).  On database worksheets, the data will be made absolute and will break reference from the original master.  But it still might prove useful to you.
I very much agree that worksheets and worksheet formatting is very handy to have in Vectorworks but feels very outdated.
I tried to reproduce this but I was not successful. In a Vectorworks worksheet, adjacent cells seem to share borders. You can turn the border on and off between any two cells from either of the two neighbouring cells. This is not the same as, for example, html, where each cell has its own border (and that comes with other quirks, like border-collapse properties etc.).
If this does not work for you reliably, that sounds like an edge case or a bug. Do you have a sample file that demonstrates this? Could you share this file?
Thanks!
I would love to understand your dream world a little better 🙂 . Could you post/DM with an example?
57 minutes ago, Pat Stanford said:
your
Thanks!
Hi @Stephan Moenninghoff, as soon as I’ve got an example of this issue, I will report it here.
Thanks.
