I've been trying to establish a robust way of getting windows that use a custom symbol to display as I want in Horizontal Section Viewports.
Basically I want to have HSVs with "display 2d components" turned on but I want my window objects to be shown in section, as in a real section through the window geometry, not a 2d component representation.
My initial hope was that if the window symbol had no "top or bottom cut" 2D component, VW would simply default to sectioning the symbol 3d geometry. That's what happens if the symbol is just floating on its own - but if it's within a window object, it just shows a blank space.
Then I realised that there are some settings that I can apply to the objects within the 3d component, using the "display with 2D components" button. Doing this makes some elevational lines appear in the window opening but no section cut geometry.
To get it to work fully, it seems that I have to put something in the 2d component (just a single 2D locus seems to do it). Then, the window appears properly.
Is this what's supposed to happen? Or is there something I'm missing? The same problem seems not to exist in "regular" sections.
I've attached a sample file (VW2023 version). There is further explanation in the sheet layer.
line-weight
customwindow.vwx
46 answers to this question
