ofiro Posted November 10, 2023 Share Posted November 10, 2023 Hi hi I'm trying to assign a second C-clamp to a moving light with the Accessory tool but after manipulating the second clamp to it place the center inserting point of the fixture is changed in 2d plot view? what is the best way to Attach a double c-clamp to a moving light? thank you. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted November 10, 2023 Vectorworks, Inc Employee Share Posted November 10, 2023 My preferred way is to create a double clamp symbol, with the clamps offset to each side of the insertion point. 3 Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted November 10, 2023 Vectorworks, Inc Employee Share Posted November 10, 2023 paging @Sam Jones Quote Link to comment
Sam Jones Posted November 10, 2023 Share Posted November 10, 2023 (edited) 8 hours ago, Scott C. Parker said: paging @Sam Jones Although AutoPlot Tools for Spotlight will allow you to specify the location of a clamp accessory, the @jcogdell method seems to me to be another good way. However, if you are planning on counting clamps, you will need to be careful with specifying the counting criteria and/or being sure that the double clamp symbol contains to symbols to count. (I think. I haven't played with this method. Edited November 10, 2023 by Sam Jones punctuation Quote Link to comment
spettitt Posted November 10, 2023 Share Posted November 10, 2023 I do @jcogdells method. Every model of moving light has it's own clamp width though, which is important for checking you're not clashing with a truss node. So I have 'MAC Ultra Performance Clamps', with the correct height omega bracket and clamps at the correct spacing for the fixture. This is pre-attached as an accessory in the symbol to minimise drawing time, but can be removed with the Accessory tool in remove mode if replacing with an alternative clamping method. IMO always better to do the work once on library content than have to add clamps each time you use the fixture. No time for that! 1 Quote Link to comment
markdd Posted November 10, 2023 Share Posted November 10, 2023 40 minutes ago, spettitt said: IMO always better to do the work once on library content than have to add clamps each time you use the fixture. No time for that! For what it’s worth that’s my process as well….. 3 Quote Link to comment
