suz Posted October 27, 2023 Share Posted October 27, 2023 Hi angular walls.vwxteam, So i have these angular shapes - at the moment no thickness. Talking to contractors they need to have 60mm steel structure inside and 12mm plywood as cladding. How can I add the thickness on all of the structure without funny corners? Also how would you approach doing tech drawings for these? Elevations etc? Really appreciate your help. Many thanks, Su Quote Link to comment
VIRTUALENVIRONS Posted October 27, 2023 Share Posted October 27, 2023 Have you tried "Shell" from the 3D tool palette? Quote Link to comment
suz Posted October 30, 2023 Author Share Posted October 30, 2023 This happens. The joints are not clean! Quote Link to comment
VIRTUALENVIRONS Posted October 30, 2023 Share Posted October 30, 2023 Hi Suz, Can you export out a VW2021 file and repost. Quote Link to comment
EAlexander Posted October 30, 2023 Share Posted October 30, 2023 Hi Suz, You've got a mass of 3D polys here to make up your design, but they don't all cleanly meet in the corners in some areas and you've got some plains that overlap behind others that met up mid point, causing corners that aren't true edges. Because of these minor errors, you can't ADD SOLID this together into one clean piece of geometry, which is what you need to be able to add thickness to it. So you need to do some clean up - use what you have as a template and redraw the surfaces with the 3d poly tool, making sure everything is clean and all points are snapped together - has to be watertight. Once you have this, as just the outer visible shell of the design, no overlaps, and no hidden internal plains, then you can use the SHELL SOLID too l to thicken it up cleanly. As for elevations - once you draw each plain cleanly - before you fuse it all together, save a copy of each and then rotate them around so they all lay flat on the same plane. I would make viewports of the assembled object from front, side, top and various sections to give the fabricators the overall "footprint" of the design and then I would give them true flattened views of each panel (might be good to name each one on the 3d and the 2d layouts) so they can figure out each panel individually. Hope that helps. e. 3 Quote Link to comment
Benson Shaw Posted October 31, 2023 Share Posted October 31, 2023 Another thing to consider is construction and joining methods. There may be separate units which need to be created separately then connected via overlap, or hinge, or bevel, to create the desired joint. For your drawing, it may be better to shell subsets instead of making the entire assembly a single shell. If possible, work with the contractor to determine options and preferences. -B 1 Quote Link to comment
Tobias Kern Posted October 31, 2023 Share Posted October 31, 2023 Hi, maybe you can use a Subdivision with Iteration = 0 to model the object and later you can convert it to a solid to give a thickness. Greetings Tobi Quote Link to comment
line-weight Posted October 31, 2023 Share Posted October 31, 2023 @suz, most of these questions were already answered in quite a bit of detail in the other thread you started a little while ago. Quote Link to comment
