spettitt Posted December 1, 2022 Share Posted December 1, 2022 Hi all, here's a fun one for you. We would like to indicate Suitability in our Title Blocks, and have a traffic light indicator for an at-a-glance indication: I have a field set up in Sheet Data to choose the suitability: How can I make the traffic light change to reflect the chosen suitability? S0 = Red, S2/S3 = Amber, A1 = Green. I can't work out how to make this work, short of a script, which I'm not familiar with yet. Maybe something with class visibilities, or three different symbols...I don't know. Any inventive ideas appreciated. Thanks! Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted December 2, 2022 Vectorworks, Inc Employee Share Posted December 2, 2022 Can you share the file? Data Vis is probably your best bet but won't work with the title block. However you could place an object with a record on the sheet. Quote Link to comment
spettitt Posted December 2, 2022 Author Share Posted December 2, 2022 Thanks Tom, I'll send you a mail. Quote Link to comment
Andy Broomell Posted December 2, 2022 Share Posted December 2, 2022 I can't think of a way to get a TBB object to do this. What I'd probably resort to is removing this field and geometry from the TBB entirely, and instead, make it all a SYMBOL. You'd have 4 different symbol definitions, one for each status, each containing the text, the three cells, and appropriate color fills. Make sure the insertion points match between all four symbol definitions (and I'd probably put the insertion point in a corner so I could snap the Symbol to the TBB easily for perfect alignment). Then when switching Statuses, just use the Replace Symbol command in the OIP to swap symbols. The disadvantage with this approach is that your Status is no longer connected to the TBB so if you're pulling this data anywhere else (worksheets) or trying to use the Title Block Manager, you're to of luck. Quote Link to comment
markdd Posted December 2, 2022 Share Posted December 2, 2022 (edited) I've come up with this symbol which you could add to a design layer. It would be much nicer if one could link to data in a the Title Block Border sheet data, but that option is not available to boilerplate users such as me. The file includes a Data Vis as well as a symbol which would accomplish this but the issue with Data Vis is that it is only available on Sheet Layers via viewports. Go to the Data Tab of the Symbol in the Object Information Palette and you will see a pop up with four conditions. Each are aligned to the Traffic Light Data Vis which should change colour depending on the condition. Hope this helps a bit. Traffic Light Symbol.vwx Edited December 2, 2022 by markdd Quote Link to comment
markdd Posted December 2, 2022 Share Posted December 2, 2022 The only other route that I can think of that will allow you to do this from a Title Block is to use an emoji!! (Actually works quite well) Traffic Light Symbol.vwx 3 Quote Link to comment
Pat Stanford Posted December 2, 2022 Share Posted December 2, 2022 How about this proof of concept. This is a Data Tag that uses IF statements to show a solid circle emoji or an open circle emoji depending on the setting of the Drawing Stamp. This one only uses Preliminary (Red), Not For Construction (Yellow), Approved (Green). Thanks to @markdd for the emoji kicker. You might actually want to use a font like Zapf Dingbats instead of the emoji as I had a hard time finding open and closed circle emoji that are the same size. Traffic Light Symbol. 2.vwx 1 Quote Link to comment
spettitt Posted December 2, 2022 Author Share Posted December 2, 2022 Thanks everyone for your help, some great ideas. I had arrived at Andy's idea before posting, my original image is a symbol with hidden loci in each corner for easy alignment, but I thought a drop down would be even slicker. I've got the emoji option working quite well by trial-and-error of different fonts, but running from a drop-down in a Record rather than the drawing stamp. The emoji option is easier to operate, but the symbol option allows better control over what it looks like, so I'll run with them for a while and see what sticks. Thanks all! 2 Quote Link to comment
