Hans-Olav
682 -
Posts posted by Hans-Olav
It works here on MacOs Catalina.
Maybe dowload games launcher and reinstall ?
Thanks a lot Pat, as always helpful.
Im trying to make some reports
Listing :
- Type is wall
- Layer name starts with 4385*
"start with" and "end with" class name, layer name used to be options when typing *?
Am I just getting old?
Kind regards
Hans-Olav
It was @AlanW not Andy (-:
Hi @Angel
I could not find it but I remember @Andy Broomell made a Marionette that does what you are asking for
@Victor S You have to recalculate the DTM to make the changes show. Also be aware of the proposed or existing settings for site modifiers and texture beds must match the settings of the DTM
I missed the presentation. Any change you will post a recording? @JuanP
- 2
6 hours ago, Pat Stanford said:
OK. So you see, I found the problem. I mean. Yeah. I mean. Right. Ok. I meant to do that. I meant to do that as part of the course. Of course I did. I wanted to make a mistake and see if you are learning enough to figure it out. Right. You believe me right? Really, you really believe me, right??
Haha I was wondering if it was the case. However I tried to analyze the code but could not see what was wrong or how to improve it. Hopefully this tread can help more people looking for similar solutions. Thanks a lot @Pat Stanford
Thanks a lot @Pat Stanford I can almost understand what you are writing
My first test did not go well, VW got unresponsive, but I will try more later today and report back.
Thanks again!
- 1
If you @Pat Stanford are willing to teach me?
- 2
Hi
I have a file with lots of apartments organized as symbols
I have a made a worksheet listing all symbols starting with "apartment-nr" and in the next column i count them.
Inside each symbol there are several spaces.
Is it possible to find the total area of spaces inside each symbol? Total Net area
Have you tried the Create Wall Recess comand?
- 1
If you want to see them all together they must be in same scale. However you can make a sheet layer with viewports and have them in different scale
- 1
Hi
Are your layers of different scale?
- 1
Hi
is good on metal and is convenient as it imports straight through the import mtexture command
- 3
Hi
If your plants are hybrid symbols you can have a 2d graphic fro plan view and use an image prop as the 3d part.
check it out here:
Linetype style for CUT object ONLY.
in Troubleshooting
Posted
Hi
If it is 3d objects and you make sections viewports you can assign a linestyle and weight to the sections style.
https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FViewports1%2FAdvanced_section_viewport_properties.htm&rhsearch=section&rhhlterm=section&rhsyns=
