KIvanov
Vectorworks, Inc Employee
    295
Reputation
109 Spectacular
1 Follower
Personal Information
  • Location
    Bulgaria
Recent Profile Visitors
  1. Hi @jasongillman, Could you add a bug and we will analyse it? My guess is that it could be a new bug. Best Regards, Kostadin Ivanov
  2. Hi @LeeElston, This sound as a bug. I could suggest a workaround of the problem(the problem is that there is a polyline with radius vertex). The workaround is to convert the polyline to a polygon. This is a short video on how I fix the file. Best Regards, Kostadin Ivanov PDF.mp4 wall acoustics_fixed.vwx
  3. Hi @pcoleman, My recoment is to remove the "Wrap text" and to set "Left" and "Right" constraints of the text and the line. I attached my suggestion on how to fix the style. Best Regards, Kostadin Ivanov Rigging Marker Test File_Fixed.vwx
  4. Hi @pcoleman, Could you attach a simple file with your data tag and if you are able to show what results you expect I could try to help, if I am able to do it. Best Regards, Kostadin Ivanov
  5. The 'Data Tag Referenced Location' functions were added for VW 2022 SP3.
  6. Hi @pcoleman, It is possible to show the coordinate of the leader of the data tag, if you use the General Function "Data Tag Referenced Location". I attached a short video to demonstrate how it works. Best Regards, Kostadin Ivanov DataTag.mp4
  7. Hi @C. Andrew Dunning, I removed the right alignment of the dynamic texts and this is the result - Test.vwx. I am not sure whether this is the expected result. @Nikolay Zhelyazkov, do you have another suggestion, how this can be solved? Best Regards, Kostadin Ivanov
  8. Hi @JasmineTamara, You can use the worksheet functions #WS_AREA# and #WS_PERIM#. I attached a simple test file.Test.vwx Best Regards, Kostadin Ivanov
  9. Hi @Grzegorz Krzemien, What do you mean that data tag disconnects from objects? In your file all data tags seem to be associated correctly. About data tags inside symbols: in VW2023 we add a new option "World-based data tag" and I recommend to use it, if you want the data tag to be placed inside a symbol: Best Regards, Kostadin Ivanov
  10. Hi @gfilippini, The problem is that one file uses IFC4 and the other file uses IFC 2x3. The data tag style takes the information from IfcWallStandardCase which is default when the IFC is 2x3. The default IFC entyty for IFC4 for walls is IfcWall, so this data tag style could not take information from it. for IFC4 you should use another data tag style. IFC.mp4 Best Regards, Kostadin Ivanov
  11. Hi @station, Could I ask you for a video, because I am not able to reproduce the problem? Thanks, Kostadin Ivanov
  12. KIvanov
    Data Tags
    Hi @DomC, You can try the function DT_AssociateWithObj. Best Regards, Kostadin Ivanov
  13. Hi @gester, If benelux windows and doors are implementing the "Energos" interface, they will be included in calculation. This depends on the developers of benelux windows and doors. Best Regards, Kostadin Ivanov
  14. Hi @drelARCH, You can customize the default "Display" in Libraries\Defaults\Energy Analysis\EnergyUnits.xml. If you change: <UValue> <IsUsed>true</IsUsed> </UValue> Best Regards, Kostadin Ivanov
