KIvanov
Vectorworks, Inc Employee
    212
Everything posted by KIvanov
  1. KIvanov
    Data Tags
    Hi @DomC, You can try the function DT_AssociateWithObj. Best Regards, Kostadin Ivanov
  2. Hi @gester, If benelux windows and doors are implementing the "Energos" interface, they will be included in calculation. This depends on the developers of benelux windows and doors. Best Regards, Kostadin Ivanov
  3. Hi @drelARCH, You can customize the default "Display" in Libraries\Defaults\Energy Analysis\EnergyUnits.xml. If you change: <UValue> <IsUsed>true</IsUsed> </UValue> Best Regards, Kostadin Ivanov
  4. Hi All, This is a short video how you can put the extracted data into a record attached to a data tag and then to list it in a worksheet. Best Regards, Kostadin Ivanov Data Tag.mp4
  5. Hello Andy, This sound as a bug. Could I ask you to add it and we will try to fix it. Thanks, Kostadin Ivanov
  6. Hello, We was able to reproduce the issue (when the default database does not exist). @iborisov will look it. Best Regards, Kostadin Ivanov
  7. Hi @Amorphous - Julian I was out of the office from 16th April till today. Could you send me a steps or video how to reproduce the problem? I was not able to reproduce from blank file. I guess that your data tags were disconnected before publishing, but you do not see this, because they are not reset. The exporting of PDF has option for resetting plug-ins. Could your data tags/file be broken before exporting? Could you reproduce the problem from a blank file? We need a steps how to reproduce the problem otherwise we cannot fix it. If you able to reproduce the issue from a blank file this will be very useful. Also if this is related with project sharing we need to know this and steps how to be reproduced. I added a short video with steps what I am doing. Best Regards, Kostadin Ivanov Data Tag.mkv
  8. Hi Eric, For shifting I am not sure whether this is same issue. If you are able to add a bug (or to send a test file with steps how to reproduce) for this We will analyze it. Thanks,Kosta
  9. Hi Eric, If you use project sharing, the problem is fixed for VW2020 SP2. The fix will not reconnect automatically disconnected data tags. After the fix the data tags will not lost them connections anymore. Unfortunately you have to reconnect disconnected data tags manually. If you still see this issue, could you send me a test file with steps how to reproduce? Best Regards, Kosta
  10. Hello Eric, I have a few question. Which version of Vectorworks do you use? Do you use project Sharing? Thanks, Kosta
  11. Hi @Amorphous - Julian, The problem with project sharing and data tag is fixed in VW2020 SP2. Best Regards, Kostadin Ivanov
  12. For the moment workaround is to unlock the referenced objects, then you will be able to tag them.
  13. Hi Julian, I think that SP3 will be released this month. We do not have plans to add this functionality for VW2019. Best Regards, Kostadin Ivanov
  14. Hi Christiaan, Could you send me a test file and I will analyze it why the formula "#AnyIFCEntity#.#Pset_WallCommon#.#Reference#" does not work? Thanks, Kostadin
  15. Hi All, I looked the short video of Christiaan and I saw that the wall in his file has ifcWall. The default Wall Tag w Leader is looking for ifcWallStandardCase and this is the reason why his walls does not recognized by this data tag style. If you want to recognize both IFC, I recommend to use #AnyIFCEntity#.#Pset_WallCommon#.#Reference#. I attached a simple file with modified style. Best Regards, Kostadin Ivanov New Wall Tag w Leader.vwx
  16. Hello Joshua, This is good remark. We will try to find a solution for this. Best Regards, Kostadin
  17. This is the file for VW2019: Massing Model v2019.vwx
  18. Hello Matt, If I understand correct the floor area is the area of the Massing model: and the building area is gross area: If I understand correct, I create a simple file with data tag that pulls these areas - Massing Model.vwx.
  19. Hi Julian , The fix is only potential fix. If you can give us a test file with steps how to reproduce the issue, we will be able to test the fix. Thanks, Kostadin Ivanov
  20. Hello Julian, We have potential fix for this issue in SP2 of VW2020. Best Regards, Kostadin Ivanov
  21. KIvanov
    Data Tags
    Hello Tui, I will send you a simple script how this can be done. Best Regards, Kostadin Ivanov
  22. Hello Tui, For first question you can relink data tag using its control point. For second question this is an enhancement request, so you can fill such. Thanks, Kostadin Ivanov
  23. As I can see from your file, if you use the "Sub weight" data tag style, everything is working. Do I miss something?
