gfilippini
    20
Reputation
10 Good
Personal Information
  • Occupation
    Architect
  • Location
    Argentina
Recent Profile Visitors
935 profile views
  1. Solved. Indeed I forgot something obvious: to install WinDoor for VW2024 when I update the new VW version! After I did it began to work just as expected.
  2. Hello all, I´ve been working in a file with a graphic legend associated to WinDoor windows. It was originally built in VW2023; when I convert the file to VW2024 the graphic legend looks ok. But after I edit the cell layout (and exiting edit mode whitout any change) I can´t keep it working and showing only unique values option anymore. After cell layout edit each object instance shows individually on my graphic legend and I´m not founding how to solve to have again the simplified version (non repeating cells with same value on a specific field). I don´t know if it this happenend to someone else or it´s a known issue; or may be I´m forgetting something. Any help welcome! Regards
  3. Solved quickly: This is what I do: 1) I found on my VW Cloud Services desktop folder two temp files referred to the file I was working on. Fortunately I didn´t erase them before and for some reason this files couln´t be syncronized on WV Cloud. 2) I made a copy of one of this temp fies on my Desktop (or any other HD location) 3) Changed the extension of the file to the correct ".wmx" 4) Reopen the file and save it again. Got my file working again. 5) Relax; all objects layers, classes, sheet layers, etc. were there and I can continue my job tomorrow without having to rebulid everything, Hope this help anybody in the same stressing situation.
  4. Hello, If anybody can help me it would be great. I´ve lost one of my vectorworks 2024 files After my laptop crash and restart last friday due to unknown OS or hardware error. It´s a174 MB BIM model on which I was working during all last week. I´ve tried to import layers as suggested by michaelk with no success. All layer, design layer, class, all objects gone. I don´t know if its possible to recover a previous version from Cloud Service. I do not keep additional backup files on my drive. I can send a copy of the file to recover for test if neccesary. It is 174 MB but with nothing inside apparently when I open the file now. Thanks!
  5. Hello, I have a perpetual VW Architect 2023 license. Let me know If you´re interested Regards,
  6. Hi, I had this issue working today with VW2023. It solves for me just quitting and relaunching the app. When I reopen the file 3d part of symbols appeared. The symbols were from VW library. Regards,
  7. It would be great to have this; also to control bottom (and ends?) of walls the same way. Wrapping components as with Wall closure at inserts perhaps? May be there are all wall closures: at inserts (Top-Bottom-Sides), at top-bottom and at ends.
  8. Ups! I wait this to be added! Thanks!
  9. Hi! I was wondering if this "Top of Wall" resolution has been improved. Can wall tool have a "top end cap" "wall closure at Top" or something similar to manage how to end without having to model other objects like slabs or extrudes? Perhaps wrapping components same way wall closures at inserts. I may be forgetting or not seeing something that already exists. It would be nice to have a "bottom end cap" or "wall closure at bottom" too. Thank you!
  10. Hi Kostadin, Thank you very much for your answer; I did what you show in the video and now I have Data Tags info complete and ok! Best regards, Guillermo
  11. Hello all, I´m having problems with wall data tags and text dynamic fields on its layouts to display info. After some days working on a file I found no wall info on data tags; Info was shown initially, I can´t identify what I changed on the file to get this. No changes were made to Data Tag layout. Before continuing tryng I take a little test on empty files (attached) and this occurs again: After some days file mamed "Untitled1" is not showing info on Data Tags. I create a new file "Untitled2" and Data Tags show info from dynamic text fields ok. Now on "Untitled1" file I can´t even add wall data tags anymore using the only style present on it since file creation. Any idea on why this is happening welcome! One more thing I´ve seen while working on data tag layouts: when having many of them on drawing files (on design layers) and try editing Data Tag layouts took lot of time before redrawing; not sure if this is always this way, not so good for me. Thank you and happy new year!! Untitled 1.vwx Untitled 2.vwx
  12. Nikolay, This works nice! I will use and investigate how to apply it on other cases. Thank you very much!
