497 -
Everything posted by RussU
Although I'm not an expert, I reckon what you're after would suit Marrionette perfectly. @Marissa Farrell would be able to give you much more info than I could
@markdd Of course! <hand slaps head> Thanks for the reminder!!!!
Right, cool.... got it. The grid is restricted to your page boundary. zoom right in tight to the 0,0 point, and you'll find a very small page boundary with your grid within that. or click this button... I can't think of the way to allow the grid to spread beyond the boundary, so you have two options here. Make the page size huge, or tiled many many times..... or as mark says, reduce the layer scale so you're working within the page. Anyone else remember how to allow the grid to overspill beyond page boundaries?
can you post a couple of screen grabs, before and after, so I can get a better idea?
Are you still in top/plan view? press 0 on your number pad to make sure. failing that, make sure your "show grid" button is activated, And switched on... Finally, as a last double check, double click on your snap icons to bring up the smart cursor settings (Which I think you've already done) And tick "show grid" Let us know how you get along.
splitting across multiple zip files might help?
ok thanks. I knew about surface hatches for some rw textures, but havent' had the time to use them properly just yet. It's a shame that the object will need to have a texture applied rather than being able to do it with overrides Thanks for the info though.
Bit of a back to basics question, but are you able to add class overrides to viewports and have them apply to 3d objects? I've clicked around a bit, and I would like to have a hatch overlaid on my 3d objects, but while I've got an over-ride set up it doesn't seem to show in the viewport. Also, note that the fourth coloumn doesn't show an override icon... I don't know if that might be the problem?
Thank you. Further to your note, I found that if you are in TrueView you won't have the REGEN command available. A work around for this is to change the view style from 2d, to hidden line or similar, and then back to 2d to force the regen command to happen. This also shows the lines correctly. Thanks again @Nina Ivanova 👍
Thanks, will PM the file over to you shortly. These were the last export settings I tried. I've tried both options for the "Export complex line types as Blocks" option. Thanks for your help
I'm trying to export a linetype to DWG It came in as a DWG, I've worked on it a little and now want to output, but the lines lose thier text tags on export... VW on the right, Trueview on the left. Any ideas?
Dedicated Forum Moderator (ie Jim Wilson 2.0)
RussU replied to Amorphous - Julian's question in Wishlist - Feature and Content Requests
it's not like yourself, @Christiaan , @_c_ @Bas Vellekoop and many others have been asking for a wee while now... I rarely need to use it in my day to day work. I'm lucky enough where everything is generally a custom build, I need to direct model everything for manufacture on CNC. So I need ludicrous amounts of detail, especially on staircases and the like. For me, I'd like to see the stair/door + window tool produce these cnc files, but I've never asked, because it would be a very very big ask. I don't think your comments about localisation, or @_c_ requests for rebates are unreasonable though. -
There has been the occasional feature addition via service pack, Revit import, IFC support, cloud services etc. But generally, for an overhauled or new feature you'll need to wait for a major annual release. -
are you able to pan with the middle mouse button?
Lower Subscription Cost
RussU replied to jcaia's question in Wishlist - Feature and Content Requests
The sales model for everyone has evolved over the years . If you were to introduce a monthly subscription cost then anyone who spent on a perpetual licence is going to feel an immediate bump, because other users are getting on the bus for much much less. Monthly subs certainly makes it more affordable and Adobe proudly announced that the use of pirated software plummeted when they did this. The Adobe CC suite is absolutely astonishing value when you are able to make use of 3 or more of their packages, so it's very easily justified. They've cemented thier market position forever as no competitor will ever get a look in now Pricing is important, but AutoCAD is already the "industry standard". I think one of VW strongest points is the sheer amount of import/export functions. It will play nicely with a lot of different softwares. Be careful with that! It's not so much a perpertual licence, but an end of life for maintainance and support, with financial penalty if you want to get back into the support cycle. Sure you can use the softwareforever, but any critical fixes and patches are never rolled out to you beyond two versions. There's lots of people on legacy versions of VW, but they're still running with bugs which are fixed for other people, but not for them. Just think of those poor folk who have a perpertual licence for 2013, and now because their OS has updated, they can no longer use this perpetual licence.... Perpetual, is not perpetual... Perpetual is, "you're on your own from here, kid" maybe a year, maybe two, but not perpetuity. I don't know of any other software firm which leaves legacy versions with critical issues still unpatched. The answer is not impossible to find. The intial lump sum has been paid by every VW user so dumping this in favour of a subscription will annoy the existing customer base. Instead give them a heavily discounted rate back to what VSS costs. (for me it's £550 a year, or hopefully, £50pcm soon) For those who don't want the initial outlay, raise their subscription to say £750/year, or £75pcm) for a true perpetual Software-As-A-Service Model. (OS updates won't break you!) And finally, for those who want the benefits of the first package, but cant afford the out-lay, how about £1k or £100/pcm, until they've paid their "Perpetual" lump sum, and then it drops to half. This will help grow the user-base, encourage long term use..... but crucially, from a development and support perspective, everyone will be on the latest version anyway. Completely removing the unsupported legacy version argument.... And, it'll heavily reduce piracy as well. As a final comment, one thing I'd love to see that no-one offers at the moment is a pay-per-view model. I would love to see all these photoshop/autocad subscription models offer a 5-day, pay as you go model. Some users don't want to sign in for a year. Just pay when they use it once in a blue moon. Would happily pay £10 for a week of photoshop, when I have a job to price it into, or £20 for one week of 3DS max, when I know I won't use it for 45 weeks of the year. It means I can build the software cost into the individual job, if needed. As ever, I'd love to read other user's thoughts about this. -
Thank you, very interesting. It's shown me that I am not using revisions and issues properly. I have revisions on each sheet, but no Issue data at all. So when I go to create the worksheet there is no issue data available to me. As you mentioned I cannot change the revision data in this way.
thanks @Nikolay Zhelyazkov Useful to know. I don't think I'm using the issue/revision functions as they should be, if that's the case. There's not much in the way of clear documentation in the help files or video tutorials either. If you could point me in the right direction of some useful info, that would be excellent. Thanks again.
Does anyone know how to access the revision and issue data via worksheets? I've had a huge amount of so-called revision notes to drop into each sheet and the usual title block manager way of doing things will take an age. Ideally I'd like to do direct entry with that, so any hints and tips would be really appreciated
I've published a few A3 Sheets to PDF. 420mm x 297mm - When I drag and drop them back into VW, they're consistently sized at 3361mm x 2376mm Any ideas why they're coming in at a wrong size??
After having a look and seeing what Mr S has done, you really should get him to do a few video tutorials! The viewers will love the English accent!
In the strictest terms everything in 3D is made of triangles. Even quads are two triangles, it's just when all verticies line up these 3d packages hide the triangle divider. So for a sphere apparently made of quads; Is actually made of hidden Triangles. They way each program stores and generates surfaces is very different. So Import and Export functions are generally a translator. You are right, you'll get different results with different exporters. The only real exception with this is NURBS which describe a surface. Even so, when this is rendered, it's still converted to triangles for display. VW works with Seimens NX Parasolids, so your best bet is to export to the .X_T format, and then it's down to your import options in C4D to get you the cleanest result. But the X_T format will describe the scene the best. If C4D doesn't like that format, go for IGS next and then SAT, but the key is your import options.
Why doesn't the snap pallet work like other pallets??
RussU replied to Tom Klaber's topic in General Discussion
Hi All, I see a lot of you making good use of the data tag tool, and I'm wondering how I can use it in my workflow. I don't really use many native PIOs, but I do make extensive use of custom symbols. Can anyone point me towards a good tutorial about setting up custom data tags? I don't know where to start on this Many thanks
I don't think Fundamentals has Export PDF included. Your best work around is Printing to PDF if you have acrobat or similar installed. See Tamsin's comment below!
