267 -
Reputation
206 SpectacularPersonal Information
Occupation
Technical Support Manager
Location
United States
Recent Profile Visitors
9,104 profile views
Editing notes in "general notes" object: "edit" button calls up wrong note
jblock replied to line-weight's question in Troubleshooting
@line-weight Yes, a bug was filed for this and it is still being investigated. It looks like our development team is aiming at 2027 for a fix for this. I will check to see if there is anything that can be done in 2026. The bug number is VB-203090 -
With Vectorworks 2026,Top/Plan Wall graphics are now derived from the Wall’s 3D geometry, improving reliability, performance, and support for complex features, with all Walls required to have at least one component. Component graphics display in medium and high detail while overall wall fills now appear only in low detail, and walls always observe the design layer cut plane, with inserts automatically breaking walls only if they intersect this plane. These changes simplify workflow for users and plug-in developers by reducing manual settings, though 2D symbols for doors and windows will no longer break walls unless 2D loci are included to define the wall hole. For more information, please watch the following video: WALL CHANGES 2026.mp4 Additional information on how to adjust attributes for Doors and Windows in Walls can be found HERE.
When using the Vectorworks Odyssey with Meta Quest, there some technical factors that need to be considered to achieve the best performance and experience the tool can offer. Vectorworks Odyssey is designed to handle files of up to a million triangles and 400-600 while maintaining a consistent frame rate of 72 FPS. Although some restrictions apply, that is generally the limit for a smooth experience. Please note that this complexity criteria are not directly correlated with the .vwx file size. When a model is exported to. vgx, the number of triangles is decimated, and individual objects are combined to minimize their count. To determine the number of objects and triangles in your project, open the .vgx file in the Vectorworks Cloud Services 3D viewer, either through a web browser or the Nomad app. Then, click on Settings (gear icon) and look for the "Faces" and "Geometry" statistics in the project settings. For more information, please refer to the link below: View 3D models of Vectorworks files For more information on the Meta Quest performance tests, please refer to this article: Testing and performance analysis Please note that a frame rates below 72 FPS may induce nausea in some users.
@grijurajuPlease submit a support request using the form on the customer portal so we can gather more information and get you up and running. https://customers.vectorworks.net/forms/support-request
- 1 reply
- 1
The SPS should be updated every time you upgrade Vectorworks. However, it is required to be updated for Vectorworks 2025 and for Vectorworks 2026, as these versions of Vectorworks will not work with previous versions of SPS.
What is a Showcase Record Format? Showcase is previz directly inside of Vectorworks and uses some new record formats in Vectorworks. A record format allows you to add data to drawing objects. Showcase uses the data inside the record format in conjunction with the DMX coming to it from a lighting board to manipulate drawing objects in exciting ways. Here are links to DMX Glow, DMX Transforms, and Showcase Camera fixtures in the GDTF Share. Here is a link to the current Vectorworks Help on DMX Glow and DMX Transforms. DMX Glow DMX Glow is an RGB overlay on top of non-symbol objects. It allows you to modify the color of an object by three channels on a lighting console. DMX Glow does not emit light. • Type must be RGB. • Candela must be greater than 0. It does not currently affect the “brightness” of the color overlay. • Universe is the DMX universe. • Channel is the local DMX starting address. DMX Glow requires three sequential DMX control addresses. • DMX Glow is a single-pixel video replacement for an existing image texture. For best results, apply any image texture to the object in question. Figure 1: Extrude with Glow_DMX record format selected in OIP Note: The examples in this document assume that the bottom of the drawing is “Downstage” and the top of the drawing is “Upstage.” ETC EOS Profile • This is what the profile looks like on an ETC Eos console. Figure 2: EOS RGB 8bit profile • Controlling the DMX Glow with an ETC Eos and seeing the output in Showcase. Figure 3: Showcase and Eos, blue sculpture. Figure 4: Showcase and Eos, green sculpture. DMX Transforms DMX Transforms allow users to move, scale, and rotate objects like scenery in Showcase with a lighting console. • Universe is the DMX universe. • Channel is the local starting DMX address. DMX Transforms requires 15 sequential DMX control addresses. • Delta X determines an object’s Lateral (Stage Left and Stage Right) movement. • Delta Y determines an object’s Forward/Back (Upstage and Downstage) movement. • Delta Z is used to determine the Vertical movement of an object. • All Deltas direction is relative to the item’s insertion point. IE: If you have a stage that is 40’x40’ and you would like to move an object all the way across the stage, you would need to make the Delta X 40’ and place the object on the far Stage Right side of the stage prior to starting Showcase. Note: All movement and rotation examples in this document assume the standard Front view looks in the Upstage direction. Figure 5: Chair in starting position stage right, coordinate X (Delta) X @ 0%. Figure 6: Chair at down center stage position with coordinate X (Delta X) @ 50%. Figure 7: Chair at stage left with coordinate X (Delta X) @ 87%. • Multiple Deltas can be used at the same time to position objects anywhere in space. Figure 8: Chair at center stage with both an X and Y Coordinate (Delta). Figure 9: Chair floating above the stage with an X, Y, and Z coordinate. • Rotation Axis sets the axis of the object. X, Y, or Z. • Rotation Delta is the amount of rotation is degrees. It is only used when DMX dictates that rotation control be indexed. • RPM is the maximum number of revolutions per minute the object can rotate when DMX dictates that Rotation Control is Continuous. Figure 10: DMX rotation settings. Figure 11: Rotation Axis X (pitch). Figure 12: Rotation axis Y (roll). Figure 13: Rotation axis Z (Rotation like a merry-go-round). • Only one Rotational Axis can be controlled at a time. • Scale X determines an object’s Lateral (Stage Left and Stage Right) scale. • Scale Y determines an object’s Forward/Back (Upstage and Downstage) scale. • Scale Z is used to determine the Vertical Scale of an object. • All Scale values default to 100%. Setting the Scale to 0% will allow you to “shrink” the object to nothing. Setting the Scale to greater than 100% will allow you to “grow” the object. Figure 14: X, Y, and Z scale set to 1% in the Xform_DMX record format. Figure 15: Z scale set to 70% on Eos. • Notice that when the Scale is set to 1%, increasing the Scale value on the lighting console will decrease the object's size. A great application of this is to make curtains open or close. Figure 16: Curtains closed. Note X scale value is 0%. Figure 17: Curtains partially opened. Note X scale value is 50%. • Setting the Scale to greater than 100% will make objects “grow.” Figure 18: Scale set to 300%. Figure 19: Note that the Z scale is @100%, and the sculpture has grown. • Objects will Scale from their insertion point. Offsetting the object from its insertion point can change how the Scale works. Figure 20: Object offset from insertion. • Note in the image above that the object has been offset so that the leftmost side of the sculpture is a 0,0. When we exit the Solid Addition and activate Showcase again, the object will Scale from its insertion point, in this case toward the Stage Left side. Figure 21: Object scaling from its insertion point. • Rotation Points are a misnomer. They are better thought of as Internal Insertion Point Offsets. • Rotation Point X will offset the Internal Insertion Point along the X-Axis (Stage Left / Stage Right). • Rotation Point Y will offset the Internal Insertion Point along the Y-Axis (Upstage / Downstage). • Rotation Point Z will offset the Internal Insertion Point along the Z-Axis (Vertically in Space). • Rotation Points (Insertion Points) affect the Deltas, Rotation, and Scales. Figure 22: Rotation point X set to 5’ changes the X scale effect toward stage right. Figure 23: Rotation Point X set to -5’ changes the X Scale effect toward Stage Left Rotation Points can also be used to change the direction in which a curtain moves. Both of these curtains have the same control channels. The only difference is that the teal curtain has a Rotation Point Z offset of 20’. Figure 24: Teal curtain with a rotation point Z set to 20' Figure 25: Two curtains moving in opposite directions. Notice that the red curtain is moving from the top toward the stage at the bottom, where its Insertion Point is. The teal curtain has had its Insertion Point offset +20’ along the Z axis as the bottom of the curtain is moving up toward the top. Figure 26: Rotating about Z-Axis without rotation point offset. Figure 27: Rotation about Z-Axis with a rotation point X offset of -5'. Local Video Mapping Video files can be attached to Video Plug-ins objects (Video Screens, Blended Screens, LED Screens, and Televisions) and will play and loop in Showcase. Videos can also be attached to 3D shapes, which we will cover later (Figure 28). Here is a link to the current Vectorworks help on Video Sources in Showcase Figure 28: Video screen in Showcase with local file playing. For Video PIOs, these files can be attached via the OIP by clicking the Edit Array Image (Figure 29). Figure 29: Video screen selected with edit array image highlighted. In the Edit Array Image dialog, you can adjust the Texture applied to the object. (Figure 30) Note: The aspect ratio of the texture you choose to assign to the object and associated video must match, i.e., 4:3, 16:9, etc., to ensure correct mapping. • Screen Image: allows you to adjust the texture associated with a single face of the PIO. The default texture is the Vectorworks Logo RT. • Image Adjustment: Scale, positional shifting, and tiling of the texture can be adjusted here. • Enable previs video: Activating this checkbox will allow for a video to playback once Showcase is activated. Click Select File and attach the needed video. ***Caution: The video is attached via an absolute path to the VWX file. If you share the VWX file, you must also share the video file, and the video will need to be remapped. Figure 30: Edit array image dialog box. While in Shaded mode, the image associated with the attached texture will be visible. To see the video begin to play, you must activate Showcase. Go to the Entertainment or Spotlight Menu Dropdown, Find the Showcase sub-menu, and select Start Showcase (Figure 31). Figure 31: Start Showcase. Once Showcase is started, the video will begin to play and loop repeatedly. There is no way to scrub through the video. Adjusting the Texture If you would like to adjust the texture associated with PIO, find the texture in the Resource Manager, right-click on it, and press Edit (Figure 32). Figure 32: Select and edit the texture in the resource manager. This dialog allows you to adjust the selected texture. This specific texture, Color Bars 16x9 RT, has a Glow Reflectivity applied to it to mimic the glow you get from a Video wall (Figure 33). If you press Edit next to Glow, you can Edit the Glow Shader reflectivity (Figure 34). It is important to edit the “Brightness %” field, which may take some trial and error. Figure 33: Edit Texture Figure 34: Edit glow shader. Figure 35: Video Screen Textures This Color bar texture and other Video-related Screen Images are found in the Resource Manager under Vectorworks Libraries>Defaults>Video Screen>Screen Images>Screen Images.Vwx (Figure 35). Import this Texture into your file by right-clicking and importing it into your active document. Turning a 3D object into a surface to play video: Sometimes, you may want to turn a 3D object into a plane that will display video. This is helpful in conceptualizing complex shapes that will become video surfaces in reality. In this example, I created a simple extrude that is 32’ long, 6” deep, and 18’ high, giving a surface with a 16:9 aspect ratio typical in video applications. (Figure 36) Note: The aspect ratio of the texture you choose to assign to the object and associated video must match, e.g., 4:3, 16:9, etc., to ensure correct mapping. Figure 36: Simple extrude. Now go to the Render tab in the OIP and change the None of the Overall Texture to the ColorBars 16x9 RT that we imported (Figure 37). Figure 37: Change the overall texture of the extrude. You will then have to adjust the scale of that texture, turn off tiling, and rotate the image to its appropriate orientation (Figure 38). The other faces of the extrude can be retextured using the Texture tool in the basic tool set. To retexture this specific color bar texture, you will have to rotate the larger bars so that they are vertical and the grey bar is the furthest right. Figure 38: Adjusting the render in the OIP. To accurately get the texture to the edges of the shape, you will use the Attribute Mapping tool in the basic tool set. From a front perspective, hover over the face of the extrude until you get a hand icon, and then click. This will then allow you to drag the texture on the surface and use the side handles to scale it across the surface (Figures 39 & 40). Figure 39: Front perspective, activating the attribute mapping tool. Figure 40: Reshaping the texture to take up the whole face. Select the object, and then go to the Entertainment/Spotlight menu>Visualization>Select Video Input (Figure 41). This will bring up a dialog that allows you to set a video source similar to the Enable previs video from earlier (Figure 42). Select a file and click OK. Figure 41: Select video input Figure 42: Video Input Dialog When you Start Showcase (from the same location as before), the video you attached will now play on that 3D surface (Figure 43). If you want to adjust the brightness of the screen texture, refer to Figures 33 and 34 above. Figure 43: Video on 3D object surface after starting Showcase. (Figure 44) This technique can also be applied to complex 3D shapes. Figure 44: Complex 3D shape playing video in Showcase.
While troubleshooting, Vectorworks Technical Support may require you to send in your Installer log files. Those logs contain information about the installation process, as well as hardware and OS information from the machine Vectorworks is installed on. Listed below are the steps to retrieve these logs so they can be provided to Vectorworks Technical Support for further troubleshooting. MacOS: Open a Finder Window Navigate to Macintosh HD > Users > YOUR USERNAME > Library > Logs (or Press CMD + Shift + G and type ~/Library/Logs and press <return>) Look for filenames similar to: "vectorworks_2025_VWIM_2024_9_6_11_31_47.log" with desired date and time NOTE: On current versions of macOS, the Library folder for your User account is hidden by default. The easiest way to display it is to open Finder, then hold down the alt/option key on your keyboard while clicking "Go" from the menu bar, then selecting "Library" Windows: Navigate to: C:\Users\YOUR USERNAME\AppData\Local\Temp Look for filenames similar to: vectorworks_2025_VWIM_2024_9_6_11_31_47.log with desired date and time NOTE: The AppData folder may be hidden, so you will need to click on the View menu in the File Explorer window and enable "Show hidden Files" in the View Ribbon.
jen.williams started following jblock
@AMPD Computing Services You can point to a particular server by IP address in the Login Settings dialog. This is also where you would select a module. You can edit the Logindialog.xml file in order to pre-populate the Login Settings dialog, or to disable "Don't show at startup" in order to see this dialog upon launch again. Here is an article with more information:
If you are installing Vectorworks and are seeing a message that the License Validation Failed, CLICK HERE to go to the troubleshooting page for this issue. Activation Limit You may see a message like the one above saying that you’ve reached the activation limit for the serial number you just used to install Vectorworks. This means that the serial number has been used on the maximum number of computers as allowed by our License Agreement. Uninstalling Vectorworks does not deactivate the license on that machine, if you need to install Vectorworks on a new machine after removing it from an old one, please contact Technical Support with the last 6 characters of your serial number and the Version (year) of Vectorworks you are installing. For example: Vectorworks 2025, serial number ending in XYZ123. You can contact Technical Support by filling out the support request form or calling the phone number listed on the Customer Portal Support page: https://customers.vectorworks.net/support Communication Problems You may also see an error message that Vectorworks was unable to activate due to “communication problems”. This message means that Vectorworks was unable to contact our activation servers to validate the license and activate it. Here are some things to try if you see this message: 1. Check your internet connection a. Vectorworks needs access to the internet to activate. If your machine is unable to connect to the internet Vectorworks will not be able to activate. 2. Try a different network a. Some networks (educational institutions, offices, etc.) may be configured to block the type of traffic necessary for Vectorworks to activate, if possible, try connecting to a different network to activate. Using a mobile hot spot from a smartphone is a good way to do this. i. If using an alternate network allows activation, contact your network administrator and proceed to Step 3. 3. Check Firewall Settings a. You may have a system firewall blocking Vectorworks from connecting to the internet to activate. i. You can try configuring the Firewall to allow Vectorworks to connect to the internet. 1. Windows a. How to add an exception to Windows Firewall 2. MacOS a. The system firewall is usually disabled by default, but if it is enabled the link below describes how to add an application to the allow list. b. How to allow an application through MacOS Firewall 4. Check Anti-Virus Applications a. Some Anti-Virus applications can block Vectorworks from connecting to the internet, below are some links for common anti-virus programs and how to either allow Vectorworks through or remove the anti-virus program. i. McAfee 1. Allow Full Access a. https://download.mcafee.com/products/webhelp/4/1033/GUID-A2D48FC2-9AB2-4BC6-9CC3-51F2958F568B.html 2. Uninstall a. Windows - https://www.mcafee.com/support/s/article/000001616?language=en_US b. Mac - https://www.mcafee.com/support/s/article/000002432?language=en_US ii. Bitdefender 1. Allow as an exception a. https://www.bitdefender.com/consumer/support/answer/13425/?srsltid=AfmBOooBqnK3jogJVXadwXmWfMElSVIY3d8aSV-nw7eX_vyGPjkHKMXD b. https://www.bitdefender.com/consumer/support/answer/13427/?srsltid=AfmBOoqyee7xzXIE_d_EXFqoDPMDvDw_I6tKR7TFjA9DoKoQJWMK2RBp 2. Uninstall a. Windows - https://www.bitdefender.com/consumer/support/answer/2791/?srsltid=AfmBOooBjSHocg-KtLg6p1jxazDMWi69PAyDHVwGQThWw9cx01XDconz b. Mac - https://www.bitdefender.com/consumer/support/answer/1784/?srsltid=AfmBOoojAekfEcyzrnN_Nq iii. Malwarebytes 1. Allow as an exception a. https://support.malwarebytes.com/hc/en-us/articles/360038479234-Manage-the-Allow-List-in-Malwarebytes-for-Windows-v4 2. Uninstall a. Mac - https://support.malwarebytes.com/hc/en-us/articles/360039025233-Uninstall-Malwarebytes-for-Mac-v4 b. Windows - https://support.malwarebytes.com/hc/en-us/articles/360038984753-Uninstall-Malwarebytes-for-Windows-v4 iv. Norton 1. Allow as an exception a. https://support.norton.com/sp/en/us/home/current/solutions/v6958602 2. Uninstall a. Mac - https://support.norton.com/sp/en/us/home/current/solutions/v134746139 b. Windows - https://support.norton.com/sp/en/us/home/current/solutions/v15972972 v. Kaspersky 1. Allow as an exception a. https://support.kaspersky.com/help/Kaspersky/Win21.5/en-US/227390.htm 2. Uninstall a. https://support.kaspersky.com/us/common/uninstall/12783 vi. Symantec 1. Add exceptions a. https://knowledge.broadcom.com/external/article/177496/how-to-create-exceptions-for-both-manage.html b. https://knowledge.broadcom.com/external/article/156028/configuring-exceptions-policies-in-endpo.html 2. Uninstall a. https://knowledge.broadcom.com/external/article/156148/uninstall-symantec-endpoint-protection.html vii. eset 1. Allow exceptions a. https://support.eset.com/en/kb6526-add-a-firewall-exception-using-the-troubleshooting-wizard-in-eset-windows-home-products b. https://support.eset.com/en/kb2843-create-a-firewall-rule-to-allowdisallow-use-of-a-certain-application-in-my-windows-eset-home-product 2. Uninstall a. https://support.eset.com/en/kb2289-uninstall-eset-manually-using-the-eset-uninstaller-tool 5. Consult your network administrator a. Sometimes network settings prevent Vectorworks from connecting to the activation servers. In cases where none of the above steps resolve the issue, contact your network administrator and inform them that Vectorworks needs to access the internet. You can also provide them with the link below, which lists the domains and network ports that Vectorworks needs access to activate. i. Activating and Proxy Servers info If none of the above troubleshooting steps resolve the issue and allow you to activate, please reach out to Vectorworks Technical Support by filling out the support request form or calling the phone number listed on the Customer Portal Support page: https://customers.vectorworks.net/support
https://release.vectorworks.net/nnapub/vwim/30/NNA/eng/meta/releasenotes/Update1.html
Thank you all for the additional info. I am able to replicate this with certain products. I will send this over to our development so they can work on a fix.
Are you using a keyboard shortcut to create the Viewport?
@cwojo23 Do you have Error Reporting set to "Verbose" mode in your Vectorworks Preferences? How are you submitting your crash logs? Have you submitted any Technical Support Requests or BugSubmit Forms so Technical Support can follow up with you directly?
@jimguffaw Can you send me a DM with your serial number so I can see what type of licensing solution you have? For Series E licenses, there is not a server aspect like there is with Series E.
