359 -
Reputation
195 SpectacularPersonal Information
Occupation
Architect
Homepage
https://www.vectorworksoutsourcing.com
Location
Bolivia
Contact Info
Skype
diegorodrigo@resuelvectorworks.com
Recent Profile Visitors
2,891 profile views
1.The section fill is controlled by the Section Style Class, changing it you can show different fills/hatches , etc 2. Are you creating a horizontal Section Viewport or a regular 2D plan?
Tobias Kern started following Diego-Resuelvectorworks
Congratulations!
Export 3d symbols from vectorworks in IFC
Diego-Resuelvectorworks replied to riccardo mazzoleni's topic in General Discussion
You need to assign a IFC definition to the symbols, even generic IFC definition will be enough, otherwise the objects will not be recognized by the IFC softwares -
You need to define a component in the roof to clip the walls
Put a 3D locus to each of the points you want the fence to lock, then use the 3D mode of the fence Tool
htorcar started following Diego-Resuelvectorworks
Santiago Peláez started following Diego-Resuelvectorworks
Pablo Prieto started following Diego-Resuelvectorworks
Irina started following Diego-Resuelvectorworks
Parametric tactile paving - for Free!
Diego-Resuelvectorworks replied to mng1986's topic in Architecture
Great work!!! -
A way to do it is ungroup the main roof and clip just the remaining Roof Face in Top/Plan view
RubenH started following Diego-Resuelvectorworks
How to add sink model to Base Cabinet?
Diego-Resuelvectorworks replied to Travis.Designer's topic in Architecture
With the cabinet tool you can't do that, un-check the countertop from the cabinet, use the Countertop tool and then you can create an opening for the sink, but you will have to manually adjust the size of the hole in the Countertop to fit the sink -
Unexpected view clipping in 3d
Diego-Resuelvectorworks replied to Will's question in Troubleshooting
I also have this problem, with site models I've tried several "workarounds" to no avail, any suggestions? -
Greetings I've working remotely as a consultant for several years now, with members of the forum too, if you need some help, I can provide you with my portfolio, You can contact me at any moment too! Kind regards Diego
Point cloud architectural modeling
Diego-Resuelvectorworks replied to Diego-Resuelvectorworks's topic in Workflows
Yes, I'm curious about the process to convert point cloud to mesh, can you give us some pointers? -
lizbeth.terrero started following Diego-Resuelvectorworks
Right now I have a 2 step process, first, create the planes or rectangles aligned to the point cloud, and then create walls and slabs and so on, I hope there is a better method -
Problems using 2020 with an external GPU
Diego-Resuelvectorworks replied to Hugh McClelland's topic in General Discussion
Have you tried to reinstall Vectorworks? I've been using almost the same configuration with Vectorworks 2020, Catalina and a Sonnet eGPU with an 8 gig Radeon card without any issue, or try to contact tech support.. -
When you open the Get Info dialog window for Vectorworks, you have the "prefer eGPU" option checked? -
Greetings, I've using point clouds for refurbishments projects , I usually use the Clip cube and I start adding planes (rectangles) to work as Working planes and start modeling from them, Is there a better way to use point clouds for architectural modeling in Vectorworks?
