Diego - Resuelvector
    383
Everything posted by Diego - Resuelvector
  1. That's hardly a solution, more like a workaround....
  2. With special note to the dimension tools, in Dark mode they are very hard to read!
  3. I've be working on a Shared project and had a crash, open Vectorworks back again and whenever try to open the file Vectorworks beach-ball in the resetting bounds step, any ideas how can be fixed or prevented? Thanks!
  4. Yes, that's a great idea or even list the classes would be great!
  5. The Backup and Sync app, the test i did were with project Sharing, Dropbox is far more reliable than Google Drive
  6. I've been testing the official Google Drive app for macOS and compared with DropBox the sync process is too slow over the same internet connection, we did the following test, uploaded a file in dropbox and the same file to Google Drive, in that scenario both services performed well, once you started working in the uploaded file, the problem became clear, after every change GDrive uploaded the whole file again, but Dropbox only uploaded the changes to that file. The result, Google drive is less expensive but slow than Dropbox when uploading the changes, Dropbox is more expensive but much faster because only uploads the changes to that file.
  7. Sadly most of the Vectorworks operations are still single-core, so at this point is irrelevant how many cores we have, since Vectorworks cannot use them, unless you are using Renderworks.
  8. Works with Google Drive but is painfully slow, because GDrive uploads the whole file every time something changes in the file, DropBox only uploads the changes to that file so is much faster
  9. The "Update" Button has to go, Vectoworks need to use the idle cores in the modern CPU to make the updates real-time.
  10. After long talks with people inside Vectorworks, the wall tool is very complicated to update because is part of the foundation of Vectorworks, and has a ton of legacy code that nobody what to mess with... Maybe the solution is a new wall tool, build from the ground up like the Curtain Wall tool, to start replacing the legacy Wall tool.
  11. Yes, please, the Wall framing tool is ancient and, for example, lacks the ability to change the profile of the studs, like using metal "C" studs instead of the wood studs.
  12. Hi Harry, I'll be happy to help you, I've worked with several members of the forums before with excellent results. Kind regards Diego
  13. Hi @mbellini I can help you with that, I'm a Vectorworks instructor so I've done similar step by step guides in the past. Kind regards Diego
  14. Can you share the name of the BIM manual you are reading? To see the context of that statement.
  15. For the roof is better to use the Roof Face command, that way you can make a roof with just one fall. The round wall in the top is a little bit trickier, you'll need to add several points to the top and move each point following an arc.
  16. I've sent a private message with my number..
  17. Greetings, I've worked with several members of the forum before and I have a Vectorworks-only outsourcing service, I'll be glad to help you.
  18. Check if your wall core is 6", maybe is getting the 4" from the core thickness..
  19. For a round window, you will need to create a 2D/3D symbol, Vectorworks will no bend a window to adapt to the round wall.
