Diego Rodrigo - RV
    387
Everything posted by Diego Rodrigo - RV
  1. The best approach to create a simple, solid standing seam is to use the Framing Member and add a custom profile of a standing seam metal sheet, then duplicate it along a roof. However, this method will break down if you have complex roofs. Alternatively, you can use a Surface Array with a 3D symbol of a standing seam metal sheet. Both methods are somewhat overkill and can make your model a little heavier to manage.
  2. Review of whether you are using the right Section line class and if that class is ts with a solid fill
  3. Hi Mike! I usually start by slicing the model very thinly at 2 or 3 feet intervals for all the floors of a point cloud and saving views for the Floorplans, and also several slices for sections And try to find averages between corners of rooms, because the point cloud will have a ton of points and they are not like perfectly aligned in straight lines A good software for extracting lines from point clouds is PointCab, it's a little expensive if you do a couple of point clouds a year, it's a cross-platform software and great for point clouds
  4. A good way to do improve that is using referenced files, I'll reduce the file size and improve performance
  5. You will need to use several NURBS curves to achieve that or a play with subdivision modeling
  6. Sadly for the underside of the stairs, I find myself doing some acrobatics too if there is a lot of space between the underside and the actual stair structure Usually, I leave that part for the CD set, in DD sets I use 2D linework in sections until the design has been ironed out When, if, the design moves forward then I'll play with Roof faces and wall components to even obtain schedules and BOM
  7. Is better to not use the railings built on the stairs, I had better results using the new Railing tool in 2024, you can control better how different flights of railing connect to each other
  8. Thank you, I'll check those options to see if I have the values and settings right
  9. Greetings, I have a Vectorworks model and it is georeferenced but the moment I export the file to IFC the georeference information gets lost, even if in the Site Data the Reference Latitud and Logitud are displayed correctly What other settings must I check to ensure a proper georeferenced export from Vectorworks 2023?
  10. Hi @Pat Stanford, did you manage to fix this issue? I have the same problem
  11. Yes, I don't usually do that,I clip the roof and add a custom Skylight symbol
  12. For Skylights, the only way is create a Custom Record and a Custom Tag to show the desired info
  13. Yes, a quick fix in your situation, could be to use a 2D polygon to clip the underside of the slab, It would give you the desired section detail
  14. I hope there will be an option to access this plug-in through the Partner Products portal, is in german, but the plug-in does some amazing stuff
  15. 1.The section fill is controlled by the Section Style Class, changing it you can show different fills/hatches , etc 2. Are you creating a horizontal Section Viewport or a regular 2D plan?
  16. You need to assign a IFC definition to the symbols, even generic IFC definition will be enough, otherwise the objects will not be recognized by the IFC softwares
  17. You need to define a component in the roof to clip the walls
  18. Put a 3D locus to each of the points you want the fence to lock, then use the 3D mode of the fence Tool
  19. A way to do it is ungroup the main roof and clip just the remaining Roof Face in Top/Plan view
  20. With the cabinet tool you can't do that, un-check the countertop from the cabinet, use the Countertop tool and then you can create an opening for the sink, but you will have to manually adjust the size of the hole in the Countertop to fit the sink
  21. I also have this problem, with site models I've tried several "workarounds" to no avail, any suggestions?
  22. Greetings I've working remotely as a consultant for several years now, with members of the forum too, if you need some help, I can provide you with my portfolio, You can contact me at any moment too! Kind regards Diego
