Dmoozak Posted January 15, 2020 Share Posted January 15, 2020 First, I'd just like to point out that I'm still somewhat new to VW and extremely new and self taught when it comes to the Marionette tool. So, I created an underground catch basin with several in and out pipes for drainage purposes. Now, the way I put together the script is probably not the easiest or correct way to do it, but the object surprisingly works well in my mind. Now, I want to see if it's possible to get all of these dimensions referenced in a database worksheet. I've tried researching a little bit, and If I understand correctly, this process happens within the script level; I just don't really have a clue on how to do it. I've attached the file I'm working on and a screenshot depicting my question. If there's anything I can provide or clarify further for anyone, please let me know! Thanks in advance for any assistance! - DM Catch Basin_Marionette Object (Worksheet Practice).vwx Quote Link to comment
m.graf Posted January 16, 2020 Share Posted January 16, 2020 (edited) @Dmoozak take a look in this file, In the "Marionette Object" i have connect one Parameter "CB-Outer Radius" greatings C_B_(Worksheet Practice).vwx Edited January 16, 2020 by m.graf 1 Quote Link to comment
Dmoozak Posted January 16, 2020 Author Share Posted January 16, 2020 @m.graf Exactly what I was after, thanks for the help! Quote Link to comment
Pat Stanford Posted January 16, 2020 Share Posted January 16, 2020 So the trick in this case is to edit the marionette network to take the parameter entered in the Shape Pane of the OIP and also store that value in a record.field for access by a worksheet. That is a cool trick, but it would be much nicer is there was a way to directly access the marionette "fields" rather than having to manually do it with 3 or 4 extra tiles for each field you want to be able to access. 1 Quote Link to comment
M.Graf TH-OWL Posted January 17, 2020 Share Posted January 17, 2020 @Pat Stanford DomC has built a node do get the OIP Parameter ("hidden in json load"). I have also try to get the OIP Parameter, because I wanted to change the Parameter for every Marionette Object directly in the Worksheet. 3 Days "try an error" - with no result! 😞 This Funktion is on my wishlist since 2018... Greatings M.Graf 1 Quote Link to comment
Pat Stanford Posted January 18, 2020 Share Posted January 18, 2020 That is a very nice function, but I would still like to be able to access and edit Marionette data directly from a worksheet. Quote Link to comment
MRoth Posted January 21, 2020 Share Posted January 21, 2020 Acess works without problems. Mrnt Params.vwx But I am not able to script a bidirectional function. Maybe someone knows how something like this could work. 1 Quote Link to comment
m.graf Posted January 21, 2020 Share Posted January 21, 2020 @MRoth very nice! without VW scripting / only with Marionette also works in one direction. The fieldvalue is changeable... no impact. Is the Script warning normal? I don't see it before. Is it possible to create or get malware by Marionette / Phyton? Simple_Test_OIP.vwx Quote Link to comment
Pat Stanford Posted January 21, 2020 Share Posted January 21, 2020 The dialog box looks like it is from a worksheet script, not from the Marionette. And yes it is normal when you run worksheet scripts. Any scripting language has the possibility of being malware. The risk of something bad increased substantially when Python was added as a scripting option because it could much more easily access the entire file system than Vectorscript ever could. Quote Link to comment
