I use the Loft Surface tool a good bit, but I find it's output to be highly unpredictable. In the photos below, I'm trying to loft a surface from 3 nurbs curves that have been derived from the same original shape (so all are 3-degree curves, all the same direction). When I select them, the path indicated before I hit enter seem correct--it's a curve beginning at one curve, passing through the middle curve, and ending at the last curve. But when I hit enter and go to preview the Loft output, the path changes and now it's as though it's looping around the 3rd curve to connect to the...inside? I'm not sure. If I rotate this whole collection of curves into different 3D orientations, sometimes the extent of that weird looping around changes, even though no change has been made to the relationship between the curves. What the heck is going on? How do I get it to loft me a surface like the initial preview line suggest it should?
jbelsky
Loft Problem.vwx
12 answers to this question
