File was working fine, when I noticed something with a cased opening in a wall not displaying correctly. When I went to the 3d Model, the whole model disappeared. As I rotated the model, it showed up, but as I continued to rotate it, it disappeared again. The movie file attached shows this display issue.
Seems the file is corrupted somehow. It happened on another file, a much simpler project, that we were able to copy all the objects into a new drawing file, and everything worked fine in the new file.
I have restarted the computer, and VW, and still the same problem.
Also have had several crashes involving the Object Info Palette when trying to add or subtract a number from an existing object's dimension (like a door height or width). This is not good....
