bob cleaver
anyone using the service select for rendering
I would like the service select component of vectorworks to render sheet layers while I work on a local copy of the file.
Is this possible ?? a workflow ??  should I frequently send a copy of the file to the service select ??
2 answers to this question
I must admit I don't completely understand the cloud rendering thing in Vectorworks. I played around with it once and was a bit confused - hoping some better documentation comes along.
I didn't have a lot of success for a variety of reasons. One of the main drawbacks is it doesn't re-save your file with the viewports rendered. If you catch a mistake in the PDF it generates, everything has to be generated again. You can't just open the file locally, fix the error and output a new PDF.
Kevin
