glyd Posted February 21, 2017 Share Posted February 21, 2017 hello everyone, i just need some help. im making 2D plan in 2014VEctorworks after i finished it and saved , then when im opening it in the morning the ojects are all disappeared. like the walls,lines, text and even the grids line.. how can i fix it? im so imbarrass because it was finished already.. thank you.. i hope you can help me:) Quote Link to comment
0 Pat Stanford Posted February 21, 2017 Share Posted February 21, 2017 Often when things disappear it is the result of Class or Layer visibilities. They should not change by themselves, but sometimes appear to. First make sure that both the Layer and Class visibilities are set to at least Show Others (Show/Snap, Show/Snap/Modify are also OK). Then make sure that the appropriate Classes and Layers are set to be visible, not invisible. It that does not solve the problem, make very class and every layer visible and see if that shows your objects. Quote Link to comment
0 bcd Posted February 21, 2017 Share Posted February 21, 2017 Check the file size. Are you sure you're opening the correct file? Browse to it rather than selecting File>Open Recent. If you have more than one Design Layer make them active one at a time. Zoom out, Zoom in . Sometimes the objects are there but an errant object makes the drawing 1ly wide and they're impossible to see. Edit>Select All and look in the OIP to see if any objects are selected. Quote Link to comment
0 J. Wallace Posted February 21, 2017 Share Posted February 21, 2017 I had this issue when my video card was starting to get maxed out...upgraded the card and viola! Quote Link to comment
0 SamIWas Posted February 21, 2017 Share Posted February 21, 2017 Can you post the file? Quote Link to comment
glyd
hello everyone,
4 answers to this question
