Brooklyn
Beginner's Question - 2D and 3D
I've drawn plans and some lines and structures lie flat and can be seen in oblique views of the plan, and others remain in plan view. See image.
How can I put all the lines into the oblique capable view so I can build a 3D model on them?
Its in the View menu. Under Align Layer Views. There is an option to show Screen objects in active layer. You will need to uncheck that. You should probably investigate further screen and layer plane objects and the differences between them.
Hope that helps
Edited by markdd
@BrooklynHi if some are on screen plane and some on layer plane there is a script by By Petri Sakkinen 2010 that changes them all instantly, its a Plug-in . Attached is the Zip file for Mac and PC. Read the instructions in the Documentation PDF. Pretty simple and works a treat.
HTH
PlaneMode (1).zip
Edited by Alan Woodwell
Brooklyn,
It's even easier than running a script. Select All, then in the OIP, under the Plane menu (which should be blank because you have objects selected on multiple planes), select "Layer Plane". Now all your objects will be moved to the Layer Plane.
Next,  go to the Active Plane menu at the top of the drawing window and select "Layer Plane". Everything you draw will now be drawn on the Layer Plane.
HTH,
Raymond
And don't forget that a similar Appearance happens (when using more than 1 Layer)
and "Unified View" Option is OFF:
HTH
PlaneMode (1).zip
I have maybe a similar script, not sure its the same.  Can you confirm this works in 16/17 Alan?
Yes works 2016 &2017 I have it as part of a menu on top bar and one click change all. Offensive get drawing with a mix to work on Andy this works a treat.
