Brooklyn
71 -
Everything posted by Brooklyn
My project is on a 24" x 36" Sheet Layer, which contains eight 2D plans and sections created from individual design layers in the file. The Design Layers are at 1/4"=1'-0" and the Sheet Layer is at 1/16"=1'0". The resulting image files from the Export are very disappointing. Detail is lost, lines and text are exaggerated and fuzzy. Dotted and dashed lines done in one style are shown in another. I've tried different things to little avail. I'm attaching the VWX file and my best Export JPG file done at 600 dpi, wireframe. What might be causing these problems? Is this as good as it gets? Is there a step-by-step process for getting accurate image files from VW Sheet Layer drawings? Is the scale change the issue? Thanks in advance . . . VW Community help is great! Ed in Brooklyn 20171024_KST_3-Lev+Alley-01.vwx
Strange . . . SELECTION (Arrow) Tool goes to 2D POLYGON Tool on clicking
Brooklyn replied to Brooklyn's topic in Architecture
Please ignore above . . . I figured out what was wrong. I had inadvertently selected the 'Polygonal Marquee Mode' rather than the 'Rectangular Marquee Mode'. This is what happens when one doesn't use the application every day !!! -
Today a strange thing happens. When using the SELECTION (cursor arrow) Tool for the initial selection of a line or other object it worked OK, but when LEFT CLICK is activated to move or change the dimension of the line or object, the cursor immediately becomes the 2D POLYGON Tool. This happens on all the selection functions, like selecting multiple items inside a drawn rectangle, etc. I've installed the latest Service Pack (4) and quit and re-opened VW several times. But the condition persists. Apple Sierra OS. VW Architect 2017 Thanks !!!!
I'm only an occasional (but enthusiastic) user of Vectorworks and need advice for a rather robust project. When modeling exterior walls with painted finish on the inside and, say, brick veneer on the outside, what is the best strategy in VW? Make the wall out of two separate volume layers using shaders for color and texture . . . corresponding to the way the wall is actually built? Or, Applying color and texture to the faces of a single wall volume . . . essentially painting on the color and texture, assuming this is possible in VW (as it is in Sketchup)?
Issue solved !!!! I had been drawing in TOP view rather than TOP/PLAN. this kind of thing happens when one doesn't use the program that often. Thanks for looking, though. /////////////////////////////////////////// I've installed VW 2017 on a new iMac with OS Sierra. Even though the box in 'Preferences' for scaling line weights is checked, the lines in my drawings remain constant. Below are screen shots of approximately the same area to illustrate, along with the VW Preferences pane. Any ideas? Added Note: When working with VW 2016 on my old Mac Pro with Mavericks OS the line scaling worked fine.
Data doesn't appear in Obj Info palette when a line or shape is selected
Oooops !!! Found the problem . . . 'Visibility for the the active layer was turned off inadvertently. Typical of a too infrequent user! Thanks. -
All of a sudden selecting the lines and shapes in plan view does not produce their dimensional, etc, data in the Object Info palette. "No Selection" appears. (see image) Perhaps I inadvertently changed something, I don't know. But things seem to be OK otherwise. Using VW 2016. Thanks in advance Ed in Brooklyn
I've drawn plans and some lines and structures lie flat and can be seen in oblique views of the plan, and others remain in plan view. See image. How can I put all the lines into the oblique capable view so I can build a 3D model on them?
I'm putting a hatch texture on a 2-D drawing at 1:48. When I make it into a Viewport on a composite sheet the hatches do no scale. Can this be fixed? Thanks.
JimW, Thank you so much! I kept looking in the dialog box for the door and not in the Object Info data. Another step up the learning curve. Ed in Brooklyn.
I'm new to inserting doors and windows in walls. My swinging doors keep opening the same way and from the same hinge side. How can I reverse this? When I make the door? How? Can I do it after the door has been inserted? Thanks!
How to remove color tints from standard wall types in plan?
I guess the larger question is 'How does one edit or customize the wall types for appearance?' When I select a wall, the lines on the exterior of the wall, the 'profile' lines, are much heavier. I want all the lines to be very thin . . . like .03 mm. Right now the heavy 'profile' lines block out the finish (drywall) construction. I'm looking for thin lines and no color fill, only pattern fill--like insulation and the diagonal hatch for brick, etc. Again, thanks for any help. -
I want to use the pre-loaded wall construction types in my plans, such as "Ext Bearing-2x6-Brick." Wood is these types is pale yellow, brick is pale red. Is there any way of turning off the colors and saving the hatches to signify materials? Thanks!
Changing window types?
Brooklyn replied to Brooklyn's question in Wishlist - Feature and Content Requests
Thanks, Jim I've just copied the previous window or door and changed the parameters. And Yes, it would be great to have each in a design be a resource. -
I'm just beginning to use the Window and Door insertion tools and am having a problem. When I open the 'Create Object' menu for windows and enter the type and parameters of the new window type I want, click OK, and try to insert it . . . VW inserts the PREVIOUS window type, not the one I thought I had just created. Is there any way to have VW 'forget' the previous one? Thanks!
I can't seem to figure out how to make walls as simple bounded areas in 2D with no materials texture or components. The list after I click on the Wall selector shows only a series of common construction types. I basically just want 'profiled' walls in several thicknesses for schematic and design development purposes. Are these 'plain' walls a built-in option? If not, how can I generate them? Can I create custom wall types? Thanks! Ed in Brooklyn VW 2015
Pale green cast on screen and exported images . . .
Thanks! Worked perfectly. -
I just opened a project file done in VW 2010 with VW 2013. It is a complex 3-D architectural model. The working space has a light gray-green cast to it rather than white. Likewise, when I export the file as a .jpg image the cast is on that file as well. Any ideas where it is coming from and how to eliminate it? Many thanks! Ed in Brooklyn
Yes !!!! Thank You!
Final Quality Renderworks is giving me problems. (VW 2013, MacPro, OS 10.5.8). Usually it is quite fast even on very complex models with shaders, trees, etc. But today, for a very simple models -- only a half-dozen prismatic elements -- is it very slow. When the rendering command is given, the screen goes black for about 15 seconds and then the image appears block by block. All in slow motion. Any ideas about what's happening? many thanks in advance. Ed
