jmartinarch Posted November 18, 2015 Share Posted November 18, 2015 working on a foundation. I have a 6" conc. wall 22" tall that forms the perimeter of a square building. I have a couple of openings on one side for overhead doors. The top of the conc. wall will be 6" above my floor slab. In plan view I want to be able to show the transition. How should I "cut away" or block out these openings. Much like inserting the doors in the wood portion of the wall. The wall gets blocked out at the door opening. Do I insert doors at these locations? So there would be repeat doors on top of each other. Seems like it would create a disaster somewhere. How do you veteran VW users do it? Quote Link to comment
jmartinarch Posted November 18, 2015 Author Share Posted November 18, 2015 For the look in 2d I just put a 2d polygon with a white or 5%gray fill. This will get me through the 2d plan production. Quote Link to comment
Pat Stanford Posted November 19, 2015 Share Posted November 19, 2015 Take a look a the Notch Walls Round Windows movie at: http://www.vectortasks.com/Movies/Movies.html for one way to do it. Quote Link to comment
bcd Posted November 19, 2015 Share Posted November 19, 2015 Draw a rectangle over the wall the width and location of the opening. It Should be >= the width of the wall. Right-click>Clip Surface. This creates a Feature in Wall. Set it to be 14" high 0" from the Top of the Wall. Quote Link to comment
Markvl Posted November 19, 2015 Share Posted November 19, 2015 Man...this week is a great week for tricks and tips. Thanks bcd. Had no idea this could be done. Quote Link to comment
bcd Posted November 19, 2015 Share Posted November 19, 2015 Thanks Markvl, happy to pass it on. Quote Link to comment
billtheia Posted November 20, 2015 Share Posted November 20, 2015 I'm not sure how Pat did it because his movie wouldn't work on my computer but I usually just cut the foundation wall on both sides of the opening and change the wall height. Then I insert the door in the wood framed wall above with a negative z height to move it down into the notch I created. Good luck. Quote Link to comment
fabrica Posted November 20, 2015 Share Posted November 20, 2015 need to update that video Pat - after the intro graphics its just a black screen , can hear the dialogue but see nothing! Quote Link to comment
