Christiaan 849 Posted May 8, 2013 We've received 3D survey data in the form of a 3D symbol made from two 3D polygons to form a cross. Is there any way to convert these into stake objects or something else that the DTM tool can read? Or do we need to go back to the surveyor and ask for it in a different form? Quote Share this post Link to post
Tamsin Slatter 451 Posted May 8, 2013 Hi Christiaan Here's what to do: Create a 3D Locus somewhere away from the design. Create a 3D only symbol from the 3D Locus. Use Select Similar to select all the 3D Polygon symbols. On the Object Info palette, click Replace. Replace the 3D Polygon symbols with the 3D Locus symbol. Modify > Convert to Group. This will destroy the symbols and you will be left with 3D Loci. Each will have retained the Z value of its original symbol counterpart. Hope that helps! Quote Share this post Link to post
Christiaan 849 Posted May 8, 2013 (edited) Ah of course! Thanks Tamsin. I wonder if simply editing the existing symbol would work. Edit: yes Edited May 8, 2013 by Christiaan Quote Share this post Link to post
Tamsin Slatter 451 Posted May 8, 2013 Yes, that DOES work, BUT you end up with extra data which swells your file unnecessarily. Better to replace with the Locus, because then you get a single point in exactly the same place as the surveyor measured it. Quote Share this post Link to post
Christiaan 849 Posted May 8, 2013 Yes, that DOES work, BUT you end up with extra data which swells your file unnecessarily. Better to replace with the Locus, because then you get a single point in exactly the same place as the surveyor measured it. Yeah did that, converted to Locus, but just didn't need to 'replace symbol'. I can see where the replace symbol part of your method would be useful: if you don't have symbols to start with, but just 3D polys/lines. Quote Share this post Link to post
Cara2 0 Posted April 28, 2020 Is there a way to do this method whilst retaining the classes the original 3D symbols were on? I have many 3D symbols on many different classes. When I select them with the magic wand tool and convert them to 3D loci, following the method above, they all move onto the same class the original 3D loci was created on. This means I lose important information of what the 3D loci points represent e.g. Spot Heights, Tree Heights, Eave etc. making it complicated / creating inaccuracies when creating a site model. Quote Share this post Link to post
Benson Shaw 563 Posted April 28, 2020 I think, instead of selecting ALL of them, select each class separately and convert that selection to 3d loci, assign all the newly created loci to that class (or, the source locus can be assigned a class prior to the conversion). Select a different class, and a new 3d locus, convert, assign class to the loci. Repeat the process for each class or type of object. -B Quote Share this post Link to post
Cara2 0 Posted April 30, 2020 @Benson Shaw I did the same method as you suggested in the end. I was just hoping that there would have been a quicker method as this can be fairly time consuming when you have a lot of classes to go through! But thanks for the help! Quote Share this post Link to post
