Bruce Kieffer
Better Classes Naming
I think nested classes is a great addition to Vectorworks. Please improve the naming of these classes. Duplicating a nested class creates a real mess in the navigation palette. I'm thinking "add to group" and "create subgroup" functions might help.
Edited by Bruce Kieffer
8 answers to this question
Agreed. Duplicating a class should have an option to name the new class as you create it. Just adding '-2' is not helpful.
I think a simpler solution would be to make the navigation palette like the Mac OS finder with drag and drop. Create classes and folders, and drag and drop at will.
+1
I used to find that Duplicating a Class would also Duplicate the things in that Class so many years ago I stopped doing that. I've copied the Class Name & created a new Class & pasted the Name (& added changes) this gives me the chance to edit the class upon creation.
I note that Duplicating a Class no longer produces these duplicate, (I hope!) but I generally still cling to method of making a new class duplicate.
VW should deal with the Object Manager and the Classes like Maxon' Cinema 4D does.
Hakman,
Could you describe that for those of us who do not have Cinema 4D?
In Cinema 4D,
when creating an object it will show in the object manager in a hierarchal order with all other objects, where you can control drag to duplicate it or double click it to rename it.
You can solo an object or turn on or off a group of objects to work on the details, you can also do a wildcard search for an object. you can omit an object from rending.
There are so many good things that VW can use from C4D,
Another useful option is you can have the option to see all views of an object in the design view, like top, front, side and iso view; you can customize it how you like.
Regards
