Hakman
Content Count
89 -
Calendar
Everything posted by Hakman
That is exactly what I am doing right now... Thank you,
Thank you CipesDesign, I was trying to connect the dots using the 3D Polygon however this option is a pain, to get to the right area, we really have to circle through all the vertexes to get to the one needed so we can setup the specific height in the QIP. As far as the brick texture, it is not possible to setup a Sphere or Cylinder mapping in the QIP because it is a texturebed!
I have a site-modifier for the sidewalk and a hardscape object as a texture-bed, how can I deal with the texture-bed to be able slope to have an access to the pedestrian also the brick texture is missedup I've tried a 3d Polygon and Nurbs, on curved area it creates a lot of vertex even if I simplify them, they also slow down the system. I know on the street curb object I can remove some of the curbs but that is not the only thing I am looking to do. See attached render. Thanks
Thank you for your help J. Wallace, Please review these images to see what I mean, the slope I am after is not a smooth one.
I am not sure if my qestion is clear, what I am after, right now under 3D Type I do have Texture Bed Modifier but using this option doesn't allow a thickness of the object, I do have a 3D polygon as a site modifier underneath the hardscape but even without the 3d site modifier Polygon the hardscape as Texture Bed Modifier works because of the topography of the DTM, simply I am just looking for the thickness on a sloped walkway not as a texture bed. Thanks
I know about this option but once you have the slab option on the hardscape it will sit flat on the surface regardless of the sloped site modifier under it though.
thank you Patrick I will check the Novedge's channel, I've already tried the Service Select nothing is dealing with what I want. I know it can be done with the hardscapes as a texture bed but I am looking to have thickness and more control.
Can someone direct me to a tutorial that shows sloped hardscapes with thickness and street on a DTM, not as texture bed? Thank you,
I am having the same issue with the undo, I almost broke my computer.
Better Classes Naming
Hakman replied to Bruce Kieffer's question in Wishlist - Feature and Content Requests
In Cinema 4D, when creating an object it will show in the object manager in a hierarchal order with all other objects, where you can control drag to duplicate it or double click it to rename it. You can solo an object or turn on or off a group of objects to work on the details, you can also do a wildcard search for an object. you can omit an object from rending. There are so many good things that VW can use from C4D, Another useful option is you can have the option to see all views of an object in the design view, like top, front, side and iso view; you can customize it how you like. Regards -
VW should deal with the Object Manager and the Classes like Maxon' Cinema 4D does. -
I've had that happened before, it was due o lack of computer memory even though I had 8G of ram. Just rename the temp file that VW creates and try to open it. How big is you file? Have you tried rebooting and opening the file? then try to save it again?
It looks like this option is only available on MACs, I dont see that on the PC. Tech guys please add this option on the pc.
I am looking to do whatever you said in the last line of your message, I do know of the other options. This option is avaliable in C4D, it is a nice option.
Can we create a camera from the design view and vice versa rather than making a viewport or dragging a renderworks Camera? If not maybe it should be on the wish list
Hi, It has been an ongoing problem since VW2008, the issue of door hardware, Its seems sometimes I would be able to change the hardware and sometimes no matter what I do nothing works, it always defaults to the ugly round set. Any help? Regards
Found the link: http://www.benjaminmoore.com/en-us/for-architects-and-designers/42e51
The problem with making a separate wall which I did, Windows and Doors will only go through the first wall it touch. I ended up doing that, and customize the framing after... Which is a lot of work when there are many doors and windows. See attached image
Jonathan, Is it available at http://serviceselect.vectorworks.net ?
Jonathan, Can you please provide me with the link on your website that deals with the above matter? Thank you,
CipesDesign, That is what I have in the above attachement. Jonathan, Maybe you can show me an example, I can only select one class from the AEC/Framing/Wall Framer, so I selected the 2x4 framing part of the wall component, I get the above error.
I wish this will be possible to do, rather than framing the whole Ext wall. unless it can be done, and I am not aware of it. Please advise...
Hi, 1- Can the ceiling grid tool show these grids and tiles in 3d Rendering? its fine in 2D! 2- Can we texture the frame as metal and the tile as something else, but keeping ceiling as grid ceiling?
Thanks Christiaan
