The Hamma
Move doors with Reshape tool
I used to be able to move doors in walls parallel with the reshape tool in VW 2009 and now with 2012 I cannot. Is there a work around for this.
See images
Edited by The Hamma
Or use the Move command; a handy dialog box comes up with an arrow to indicate which direction it assumes you want to move it. Use a positive or negative number as you wish.
Thank you both methods work, but I think what I will do on most occasions is to make sure the marquee selection goes around the end point of the wall on the side that is in the direction I am going to stretch. This way the doors move and all I need to do is rejoin the wall at the end. Another trick I can use is to break the wall at some point near the stretch so the marquee selection can go around an end point. It would be nice if the tool worked the way it had in the past. I used it this way every day.
??? My Move command dialog only offers cartesian or polar coordinates. Where is this arrow? Would be great to have!!
-B
With the door selected and OIP indicated as "in wall":
press Command-M
Should pop up. Doesn't it for you?
Yes. There it is for the windows & doors. I thought I missed some feature for any object. Might be helpful occasionally.
THX
-B
Might be one to add to the wishlist - the move arrow dialogue for any object that we wish to move.
- and + do this. I hate the arrow button, it's way faster typing in a - or a + sign.
Indeed, but - or + relative to what?
What if the wall is angled 45??
By looking at the default direction of the arrow you can currently type in a + or - to make it go the way you want without having to deal with the "arrow button".
Edited by bc
Depends on the object, and the direction of the wall. It's easy once you know it. Most of the time -X is to left, -Y is to bottom.
I guess my point was that the capability you prefer is already present, is is not?
