Structure Posted July 18, 2008 Share Posted July 18, 2008 Hello there, I'm new here, but I've been using Vectorworks since Minicad 4.0. Anyway, I'm just starting to use Renderworks and I have a very basic question. How can I adjust the quality of the Render, because it always looks pretty "pixelated" or Lo-Res. And when I export it to Photoshop for touch-up, even\ though I'm adjusting the Resolution and Pixel Dimensions, it still looks pretty lo-res. Any suggestions? Thanks! Quote Link to comment
panthony Posted July 19, 2008 Share Posted July 19, 2008 (edited) It is easiest to render a small area of your model on screen so you can see the render results quickly than go to File->export image file and change settings there to increase the pixel image resolution to the desired level. The higher the res the longer it will take to save the file. Make sure you remeber where you saved the file in order to retrieve it for manipulation in PS. Pete A Edited July 19, 2008 by panthony Quote Link to comment
M.CH Posted July 21, 2008 Share Posted July 21, 2008 If you go to the menu View>Rendering>OpenGL Options you can improve the resolution. Also go to File>Documents>DocPrefs>Resolution you can also set the quality there HTH Quote Link to comment
Damon Design Posted July 21, 2008 Share Posted July 21, 2008 Try using the standard lower resolution on Design Layers-72 DPI- and increasing the Sheet Layers resolution for final rendering and exporting-say 200 DPI. This does increase rendering time but makes for a crisper image. Quote Link to comment
Structure Posted July 21, 2008 Author Share Posted July 21, 2008 Thanks for your help guys, but this one's the one that worked!! Try using the standard lower resolution on Design Layers-72 DPI- and increasing the Sheet Layers resolution for final rendering and exporting-say 200 DPI. This does increase rendering time but makes for a crisper image. Thanks!!! Quote Link to comment
cad@sggsa Posted October 9, 2008 Share Posted October 9, 2008 I have a standard setting of 300dpi and pixel width at 2000(Aspect Ratio Locked) saving to a JPEG at best compression. Only when there is a lot of light and trussing I go down to 200 or 150 dpi. Quote Link to comment
grant_PD Posted October 10, 2008 Share Posted October 10, 2008 I don't recommend JPEG actually. It's a bad format, and if you scale up your rendering you're going into jagg-ey hell. Try Tiff, which will scale up better. 150 dpi at ouput resolution usually is good enough. Quote Link to comment
cad@sggsa Posted October 10, 2008 Share Posted October 10, 2008 We use JPEG in our presentations, but will play around with Tiff. tx. Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted October 10, 2008 Vectorworks, Inc Employee Share Posted October 10, 2008 Internally VW stores images in either JPEG or PNG formats. JPEG is best when you are more concerned about size and PNG is better for quality because it is a lossless format. One trick that hasn't been mentioned is that you can copy and paste images out of VW to other applications. For example images produced by the Render Bitmap tool or rendered viewports can be pasted into other applications. For viewports set the viewport object fill to Solid before copying the image. Quote Link to comment
CS1 Posted October 14, 2008 Share Posted October 14, 2008 One trick that hasn't been mentioned is that you can copy and paste images out of VW to other applications. For example images produced by the Render Bitmap tool or rendered viewports can be pasted into other applications. For viewports set the viewport object fill to Solid before copying the image. Thanks for that Dave! I had no idea this could be done. Quote Link to comment
