Vertical Dimension Text
The only options you get for the text though are:
- Horizintal
- Horizontal/Verical
- Aligned.
The horizontal and vertical are relative to the page and not the dimension line. The Horizontal option will allow you to have dimensions at right angles where the dimensions are vertical. Where the dimensions are horizontal the text will remain horizontal though.
The short answer to your question Bruce is no.
A possible work-around:
1. Ungroup the dimension (ignore the warning note)
2. resize the text box to 1 character wide - this will give you vertical text.
3. reposition text box if necessary.
4. Re-group
This isn't entirely satisfactory, because the dimension won't automaticallly update, but it might do for the occaisional use.
  • 16 years later...
