711 -
Reputation
0 NeutralPersonal Information
Occupation
Architect
Homepage
www.mcauliffecarroll.com
Location
Trenton, NJ
Solved (via call to VSS). I did reset prefs, which did not fix problem. However if I disable the two docking options, the palettes do appear, but grayed out. With a VW restart, they stay and I can then dock them as needed. Thank you.
To clarify: Snapping & Attributes are the only 2 palettes that I cannot see, and I am using VW straight out of the box with the standard Architect workspace.
Just restarted and re-opened VW 2016, with no luck. I can see all the other palettes just fine, docked on the sides of the window...
Just installed VW 2016 and not that I cannot find/see these two palettes, even though they are checked in the Window drop down menu. Undocked all palettes and moved window about in case they were hiding but no luck. Tried quitting several times and still the same view. Odd. Any suggestions from the ether?
Problem solved! It was a OS issue and we created a new login for me to our NAS (sound of patting myself on back...)
Update- Uninstalled and reinstalled VW 2014 which did not fix problem.
VW 2014, MacBook Pro, OS 10.10.1. Tech Support is aware of this but I am interested in the VW community's thoughts as well. My version has stopped creating lockfiles and I think it is a preferences problem. I am able to open files on our server when those files are open on another station- and vice versa. We have ran tests on all four of our Macs, and have isolated the problem to my Mac. I note that I can also see open files in finder preview. I reset my preferences which did not fix the problem. This is annoying at best and dangerous at worst for us, so any ideas would be appreciated...
Is there an easy way to move the ID tags for windows a fixed dimension away from the object, without, say, snapping to a line? I have many windows in the exterior wall of a new building and the bottom of the tags overlap the window a bit. Thanks
That did it- Thanks!
I just gotta know... why does the stair object not take on the class color it is assigned to? No matter what we do it still is black, even though it shows the class color in the attribute pallet. Any ideas?
No- only 2013. Takes up too much space..
Since we upgrade each year, I'd be hard pressed to remember, but it was within the past 4 years...
That seems to only control the line type of the overhear door extension. What I am looking for is a way to reduce the depth of the dashed extension- while a section door would extend a the full door height when open, a coiling door would have a much smaller rectangle above...
I recall there used to be an option for overhead door PIO's where you could set it to either sectional or coiling, which effects the extent of the dashed lines overhead. Is this still around? Thank you.
Found it, nevermind!
