Content Count
215 -
Community Reputation
0 NeutralAbout DDDesign
Rank
Journeyman
Personal Information
Occupation
Furniture designer
Location
Melbourne, Australia
Recent Profile Visitors
Thanks Frank, it's a work-around, but not very satisfactory. 1. I am working on a front view, and you can only make symbols in plan view. 2. I want to use the object for further solids operations, which means I have to reconvert all the duplicate symbols. 3. The duplicates are still distributed in a strangely rotated way - and it's trial and error to get the symbol insertion point right. 4. The first duplicate is still incorrectly spaced. I am glad the tool has been improved in 2008.
I've been trying for years to make sense of this tool. I know I must be doing something wrong, but I also think that the tool does not behave in the way that it 'should'. In this example (with tangent to path checked): 1. The object is ever seems to be placed on the path about its centroid. This os often not what I want. 2. The object is not tangent to the path in this case. 3. The object duplicates are rotated - seemingly arbitrarily. I've tried pre-rotating the object to compensate but this does not work either. 4. The spacing between the object and the first duplicate is never what is specified. 5. The manual is no help. Does anyone else have a problem with this tool? The tool is even more difficult to use if I try to duplicate 3D objects - sometimes they don't even line up, or have a twist. Surely only ever being able to place the object on the path about its centroid is restricting the usefulness? Is there another tool that will do the job I want?
Object selection - this one had been bugging me for ages.
DDDesign replied to IanH's topic in General Discussion
I entirely agree, and I've mentioned this on several posts, but I think they've mainly fallen on deaf ears. I think most of the users here don't use inDesign and therefore don't have an understanding how easy and straightforward it is to select stacked objects this way. No messing around with stacking order. I would think it a very simple modification - and one that would not upset anyone who didn't want to use it. The second part of my selection tool modification is to have a mode whereby the selected object is the one that is dragged, not the front object. This is entirely logical, because in all other operations it is the selected object that is operated on by a tool. VW seems to defy logic in making an exception for 2D selection tool. Once again this is how inDesign works. The change would be of even greater benefit when working in 3D. This also has been the subject of several posts. -
Clip Surface Command
DDDesign replied to Benson Shaw's question in Wishlist - Feature and Content Requests
Not when I've tried it. You recompose IMMEDIATELY after decomposing. Everything that is decomposed is already still selected, you don't have to re-select anything as far as I can see. It's a quick step. Then you delete your polys after recomposing. Doesn't solve your other issue though. One thing I've often wished for is the ability of VW to do operations on groups - your cutting objects would be in a group, and you would use the group to cut.The you can edit the group. Other applications have this ability, and it would be useful in lots of situations. How many imes have I been caught out trying to o something that VW tells me I can't do, then to realize that it is because one of the operands is a group? -
Benson, Another way to edit clipped surface with internal polys: 1. Select surface - modify>decompose. 2. keeping all selected - modify>compose. 3. Select and delete reqired internal polys.You may have to send external poly to back so you can see them all. 4. Exit edit as required. -
Yes, I can, but it's exactly the same thing. The change occurs after exiting the group edit. It's like the group somehow overides the object's texture attributes, but this shouldn't normaly happen. (I thought it only happens when you ungroup and check the apply option.) I've done a workaround by ungrouping everything I can, but I still would like to know what's going on. It's happened to me before- I think I had to use another texture last time. Maybe the texture itself has something to do with it - though I can't see how. Prior to using the new texture I had another one working perfectly well as far as direction goes. But when I created the new texture it was the wrong way around and I had to change all the mappings. Which leads me to reiterate a wish that I've seen stated before - that the should be a facility to globally rotate direction during texture creation and editing. I wonder if VW2008 has fixed this.
Pete, the problem in this case is a plain extrusion.
Eport PDF (Batch) is not available on Fundamentals (Sorry, my profile didn't reflect this I've just updadated it)
I have a texture based on a filtered image. The image is a scan of timber veneer. I have a problem orienting the grain direction. I've tried rotating it in the mapping pane of the OIP but when I render FQR it appears 90 degrees out to what it appears oin the pane. Then when I exit the group edit of the group the component with the texture is in, the direction changes again. I try rotating the direction in the OIP again, then by the time I'm out of the group edit the direction is still the same. The group was part of a symbol. I had a render on the model layer with two instances of the symbol with different directions on each - that surely shouldn't be possible!? Also when I render a viewport the direction is different to the rendering on the model layer.
So I've just used the export to pdf option in VW for the first time. Previously I've always used the print to pdf capability of OSX. I usually have sheets set up with multiple pages. If I use the VW export to pdf, I get a pdf of the whole sheet with the pages ignored. With Mac print to pdf I get a nice pdf with pages, thumbnails etc. It's even not possible to tell the VW export to pdf which page to export like you can with Mac print to pdf. So I can't understand what spectifically is the benefit of VW export to pdf for Mac users -except the file size is smaller? For me it's basically useless.
Yes, and heres's what I found is strange -it happens for some corners and not others. And success can depend on which order the fillets are done. Sometimes if you can't do a corner you can fillet another corner - and then come back and fillet the unsuccessful corner later. Two other things - I couldn't find any repeatability in my tests = sometimes it workd in one one, then the next time it didn;t work. Also I tried it with metric units and didn't have any problems at all. Must be a bug.
I don't know why you just wouldn't just import them as images - file>imort>import image file... then to scale them appropriately. Sections are just 2D, so an making ann image prop, which is really a trick to make an image into 3D seems an unneccessary step.
Maybe we could wait until June 2008 before buying it - the next time there's a Friday 13 - after walking under a ladder and having a black cat cross our paths of course! Although by that time the 'internal version number' will probably be about 13.5. I don't think 13.5 has quite the same effect.
Hey, shouldn't the next version be called Vectorworks v13? Surely the folks at NNA aren't superstitious. Surely not!? And what's the next version going to be - v14 or Vectorworks2009 - or maybe Vectorworks XP? What's suddenly become wrong with consistency in version numbering?
