bhorowitz Posted December 27, 2005 Share Posted December 27, 2005 I need to create some free standing truss archs. Creating the curved truss is obviously no problem. How do I rotate this truss to an upright position? Hanging angle doesn't do it. I've tried converting the truss to a symbol and editing, but VW won't allow me to rotate it on other than the Z axis. I'm sure that there is a very simple solution, but I'm just not seeing it. Thanks, Bud horowitz Lighting Design Quote Link to comment
alanmac Posted December 27, 2005 Share Posted December 27, 2005 Try "rotate 3D" command in the edit menu. Enter 90 degrees for the angle and then choose the correct plane. No need to make it a symbol. Alan Quote Link to comment
bhorowitz Posted December 27, 2005 Author Share Posted December 27, 2005 Nope, doesn't do it. Rotate 3D only rotates on the Z axis with hybrid objects UNLESS you have the 'draw 3d only' checked in the oi pallette. Thanks Quote Link to comment
mike m oz Posted December 27, 2005 Share Posted December 27, 2005 Bud - it cannot be rotated because it is a Hybrid Object with separate 2D and 3D views. Rotating the 3D object would make a nonsense of the 2D view in Top / Plan View. If you convert it to a group in Top / Plan View you will be left with a 3D object which you can rotate. (It will have lost all of its parametric capability though.) You could then draw your desired 2D view over the top of the 3D component and create a new Hybrid Symbol. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted December 28, 2005 Vectorworks, Inc Employee Share Posted December 28, 2005 Check the "Draw 3D Only" obx in the OIP. This will make the object 3D only and then you can rotate it with the 3D rorate tool. If you want to use it to apear in 2D as a lighting position object, you will have to make a symbol out of it after you ratate it and manually draw a 2D representation. Quote Link to comment
Jim T Posted January 16, 2006 Share Posted January 16, 2006 OK I'm really confused. I'm trying to just do vertical trusses. I am using 12 and see no draw in 3d only in the Object Info box. I DO see show 3D detail. Also if I convert the trusses to group, the 3D options get grayed out. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted January 16, 2006 Vectorworks, Inc Employee Share Posted January 16, 2006 The Straight truss has a hanging angle parameter. Set it to 90 to draw a verticle truss. The curved truss has the Draw 3D only parameter to let you free rotate the truss. Quote Link to comment
mmackey82 Posted January 13, 2011 Share Posted January 13, 2011 klinzey...you just solved a problem I have been struggling with for hours...thank you. Quote Link to comment
Mickey Posted January 24, 2011 Share Posted January 24, 2011 OK I'm really confused. I'm trying to just do vertical trusses. I am using 12 and see no draw in 3d only in the Object Info box. I DO see show 3D detail. Also if I convert the trusses to group, the 3D options get grayed out. When you say 12 you mean VW version 12? I don't think the the 3d only option came out until vw2008. It was a frustrating feature for everyone, back in the day. Quote Link to comment
