bhorowitz
  • Content Count
    66
Everything posted by bhorowitz
  1. Thank you Rob. The vision guys completed 2 fixtures for me. When I update the Vision library on my Mac, they show up. The Vision library on my PC won't update. It just sits there.
  2. I'm having the same issue and I know that there are updates available. The library updates when I run the updater on a Mac, but not on 2 different windows machines. The Vision guys built some profiles for me. They update on the Mac, but not the PCs. But, even on the Mac, after updating and using the symbols they sent me for Vectorworks, no fixture modes show up in Spotlight.
  3. Understand about the GDTF files. Through Vectorworks Service Select I requested a GTD 1500 GTD Profile and an Acme 600Z. I received a response saying that these are available in the download section. I downloaded the files and pulled them into my favorites files. They are there, but no fixture modes. I also requested 2 fixtures through the Vision page, a GTD 1500 Wash and an Omarte Ares P6. I have not heard anything about these. The point of requesting these fixtures is to do a pre-viz of a show I have coming up in Beijing in about 10 days. I thought that when I imported these fixtures they would show up in both Spotlight and Vision, but apparently I am wrong. In the past, the Vision guys have built some fixtures for me. They would not show up when updating libraries in Vectorworks or Vision, and they had to send me the .wad file. Once I replaced the .wad file, all was OK. If I need fixtures built for use in Spotlight/Vision, am I better off requesting them through the Service Select page or the Vision page? Right now, I have no way to pre-viz using any of these 4 fixtures. I'm not sure which direction to go from here. Thanks,
  4. I just had the tech guys build me 2 profiles for fixtures I will be using in China. They emailed me and they show up in the new fixtures area of Service Select. I downloaded that file and added the fixtures to my favorites file. They show up, but there are no fixture modes shown. If I go to other, they are not shown under their respective manufacturers. I think that I've had this issue in the past and they have had to send me the WAD file. This is true on a Mac and on a PC. The fixtures do not show as available in Vision 2020 at all, even after updating the library. Also true on a Mac and a PC, Also in VW 2020, no matter what fixture type I insert, there is never a GDTF fixture mode available, and selecting other brings up the correct dialog box, but all that is available are generics. I emailed back to the guys who built the profiles but the email was returned as undeliverable. Any suggestions?
  5. I just had the tech guys build me 2 profiles for fixtures I will be using in China. They emailed me and they show up in the new fixtures area of Service Select. I downloaded that file and added the fixtures to my favorites file. They show up, but there are no fixture modes shown. If I go to other, they are not shown under their respective manufacturers. I think that I've had this issue in the past and they have had to send me the WAD file. This is true on a Mac and on a PC. The fixtures do not show as available in Vision 2020 at all, even after updating the library. Also true on a Mac and a PC, Also in VW 2020, no matter what fixture type I insert, there is never a GDTF fixture mode available, and selecting other brings up the correct dialog box, but all that is available are generics. I emailed back to the guys who built the profiles but the email was returned as undeliverable. Any suggestions?
  6. Problem solved. We had to go into device manager on the PC running Vision and disable the physical Wi-FI adapter. There must have been a driver change or a system file change in one of the Windows recent updates because I've never had to do this before.
  7. I've been using Vision 2019 and 2020 on a PC driven by Hog3 PC on a mac laptop using Bootcamp, Windows 10, for quite a while. I haven't used it for a few months. Both computers ping back and forth with no problem. Firewalls are off on both machines. When I try to connect Hog3PC to vision, the hog connectivity box pops up as expected. Initially, it says 'Wholehog network found' and 'installing network OK'. The moment the DP loads on Hog3PC, this changes to 'connecting'..'No Server'..'Scanning for show Port 6600'. DMX monitor shows no input in vision, Hog3PC shows DMX output. I have tried reloading software on both machines, changing the order I launch the apps, verifying that the firewalls are inactive, disabling all other network connections, etc.Issue is the same on Vision 2019 and 2020. I think that I even tried it with Hog4 PC with the same result. I don't know if it's an issue with Hog3PC or Vision. I'm completely stumped, as is my son with a BS in Computer Science. I just picked up an actual Hog 3 Full Boar. If that has the same issue, I'll be even more stumped. Any ideas?
  8. Thanks for letting me know. I have downloaded 2020, I just haven't had time to play with it yet. What does 'Flip winding order' do?
  9. Is there any chance of this being available 'on demand'? Unfortunately, I'm working all day on the 23rd.
  10. Thanks. It's just frustrating. I had VW build me a profile for a PRG Best Boy GC to replace a standard Best Boy. I thought that it would be a simple swap. I've done a bunch of fixture adjustments in Vision, so I really don't want to have to re-export the drawing from VW. I may just delete the fixture and add in the proper one. I also had an issue with Vision not showing the new profile even after you guys had uploaded it and I updated fixtures in Vision. I had to have him send me the wad file to get it incorporated. This happens on a Mac and a PC.
  11. Bummer. I had to do a lot of fixture tweaking in Vision and didn't really want to re-export from VW. Maybe I'll try deleting it and adding a new fixture.
  12. Can I change a fixture type within Vision without re-exporting from Vectorworks? Or do I have to delete the fixture and add a new one?
  13. Where can I find the latest versions of Vision for a Mac and a PC? I think that my install is corrupted and I can't find installers anywhere.
  14. Thanks Kevin I tried all that to no avail. I also had an issue with a new install of Vectorworks where I would get a window saying 'windows can't find target' right after the resource browser loaded. After clicking OK twice it went away, but the resource browser did not load my favorites. Guessing it couldn't find the directory it was looking for. I'm doing a wipe the hard drive reinstall of windows 10 now. Can you send me a link to the most recent Vision installer to bhorowitz@earthlink.net? Thanks,
  15. I will give it a try. I did update via Help menu, but did not try to run as administrator. I did have an issue where Vision would not launch due to a missing MSVCR110.dll file. I found a reference on the community board and downloaded a bunch of windows system file installers to fix it.
  16. I have been using Vision 2018 on my PC with relatively few issues. I had a major Windows crash and did a clear reinstall of Windows 10 and then Vision 2018. It launches fine, but I cannot update either the subscription of fixtures, If I select either one, I get a short spring blue circle and nothing else. No update windows. I've tried reinstalling to no avail. Do I need to do another clean install of Windows?
  17. Thanks for the fix on the beams. The focus stuff is odd. Focus doesn't work at all. When I try to use a prism in either the Vipers or Robe Pointes, the fixture acts as if is has a closed shutter in line, with no output. I am pretty sure that last time I programmed this show with Vision, in 2016, the prism functioned correctly. The Animation thing really has me stumped. If I change the type of animation on a viper (random, forward, backward, etc), either the animation blade or one of Gobo 3 gobos drops in and cannot be cleared. If I reload that v3s file, the beam is still obscured by the animation blade or robe, even if I do not have a console connected and bring the fixture up by highlighting it in the layers window. It seems that the animation blade and type shares a control channel with Gobo 3 wheel, so I'm not sure if that is the issue. I even tried building a small esc file with just 4 vipers and the same issues occur. It appears to retain this issue in the v3s file, without any dmx input. Thanks for your help.
  18. I have used Vision extensively to program tours/shows for one of my clients. This is the first time I'm using Vision 2018 and I'm seeing some unexpected behavior. Some may be usual. What I'm seeing..... 1-With both Mac Vipers and Robe Pointes, I'm not seeing anything when using Focus, and odd behavior when using Prism. 2--No matter when type of view I am in (solid, perspective, etc.), fixtures output a flat beam, visible when pointed into the house. Beams look OK when hitting the stage or backdrop. 3--Strangest of all. If I use the animation wheel on a viper, it reacts strangely and then, when releasing it, the fixtures retain something in the beam, looks like animation disk in some and Gobo 3 in some. It will not go away! This is true whether I bring up intensity on the console or from the Vision software. If I save the file in Vision, quit and then reopen, this behavior is still there even if the console is not outputting dmx or is off. I'm driving this from a Hog 3 Full Boar. Vision computer is a Desktop PC with.. Asus Turbo Geforce GTX 1070 TI video card AMD Ryzen 5 1600 Processor MSI X370 Gaming Pro Carbon ATX Motherboard 32GB RAM I don't recall having any of these issues when using prior versions of Vision.
  19. I am using CP Scenius on a large show as well. If you build these, please let me know when they are available. Thanks,
  20. Please ignore the above post. I mistakenly thought that I had a separate license for 2013. Sorry all.
  21. Boxed version of 2013 Designer with Renderworks Mac with install and Getting Started DVDs for sale. Will transfer license with Nemetschek. Please PM or email with offer. bhorowitz@earthlink.net
  22. I'm attempting to print 5 sheets of a set using the publish command. I have the sheets selected and set up to print. No matter what I do, they print to my laser printer instead of my plotter. I have selected all the sheets and gone to the options button. I select my plotter and hit print. Nothing happens. I press publish, and all are printed on my laser printer. I have page set-up set to Arch D and plotter. If I print individual sheets, all is fine. What am I missing? VW 2014. MacBook Pro i7. HP 1050 CM Plotter.
  23. After using the 'export to pdf' command for a very long time, I am suddenly experiencing some issues. If I export a drawing to pdf, some, but not all, of the text doesn't make it onto the pdf document. All text has the same attributes and are on the same layer. It seems that text blocks that were added early on in the drawings make it, and those added later don't. If I print to pdf, all is OK. This has happened to me on several drawings and has just started occurring. A drawing that might have worked successfully a week ago doesn't anymore. I've tried changing the font and reinstalling Acrobat Pro to no avail. I can't find any difference between the text blocks that export and those that don't. Any ideas?
