Iainy1961 Posted May 7 Share Posted May 7 How would I go about making a stepped seating section? It would look like this, but I can't work out a) how to extrude this as a) a gradient, b) how to put the seats in after I have done that. Thank you, Iain Quote Link to comment
VIRTUALENVIRONS Posted May 7 Share Posted May 7 Have you gone through the seating tool options already? Quote Link to comment
Jeff Prince Posted May 7 Share Posted May 7 (edited) Draw a cross section and use Extrude Along A Path (EAP) in the model menu. There are lots of examples of this particular problem here on the forum. Then, use the searing tool. Edited May 7 by Jeff Prince 2 Quote Link to comment
rDesign Posted May 7 Share Posted May 7 1 hour ago, Jeff Prince said: Then, use the searing tool. You probably meant the ‘seating’ tool. 1 Quote Link to comment
VIRTUALENVIRONS Posted May 7 Share Posted May 7 3 hours ago, Iainy1961 said: how to put the seats in after I have done that. Thank you, Iain The seating tool is amazing, but did not work in this venue. Below this picture is a short video explaining the seat placement process of this venue as it is an irregular ellipsoid shape. 1 Quote Link to comment
Jeff Prince Posted May 7 Share Posted May 7 57 minutes ago, rDesign said: You probably meant the ‘seating’ tool. Yes, either autocorrect got me or my plans to cook dinner. 1 Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted May 11 Vectorworks, Inc Employee Share Posted May 11 Hello, You should also check out @michaelk excellent Theatre Row plug in: https://www.verysmallgroup.com/vectorworks-plugins Cheers, Peter 1 Quote Link to comment
