Tyler Forsberg Posted March 21 Share Posted March 21 (edited) After installing update 4, Vectorworks has become quite noticeably slower. To the point that it has disrupted my workflow to the point that I have to add 25% more time to each project. The startup time is ridiculous (averages 2 minutes), navigation speed has decreased considerably, caching graphics runs slower, and overall this update has been a processor killer. I compare all of these notes above to Update 3, which was fine, but this update feels VERY similar to 2017's Service Pack 2. The number of crashes are up, the amount of productivity is down, and frustration with my workflow being faster than this update can process is at an all-time high. There are so many cool new features with this update, but I can't be the only one who's experiencing this. I'm not running a super computer or anything, but the difference in this update is palpable. Tyler Edited March 21 by Tyler Forsberg 3 Quote Link to comment
mjm Posted March 21 Share Posted March 21 1 hour ago, Tyler Forsberg said: I'm not running a super computer or anything, but the difference in this update is palpable. Tyler AGREED 1 Quote Link to comment
c.markus Posted March 22 Share Posted March 22 did you update your graphics adapter driver after updating Vectorworks? Quote Link to comment
dvdvarch Posted March 27 Share Posted March 27 The same problem here. Any success in solving the problem? And also here: and here: Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted March 27 Vectorworks, Inc Employee Share Posted March 27 Hello @dvdvarch if you are on Windows and you are seeing slow launch and performance (unusably slow to do anything) this may be a known issue related to the AI Visualizer and removing the GenerateImage plugin from the Plugins folder may help. There is another update coming to address that problem ASAP. Quote Link to comment
dvdvarch Posted March 27 Share Posted March 27 Thank you Dave, for now I have solved going back to Update 3, thanks to the Italian distributor that has helped me. Since the main reason for me to update was to try the AI visualizer I will wait for the fix. 1 Quote Link to comment
Jacob@tangably.com Posted March 28 Share Posted March 28 18 hours ago, dvdvarch said: Thank you Dave, for now I have solved going back to Update 3, thanks to the Italian distributor that has helped me. Since the main reason for me to update was to try the AI visualizer I will wait for the fix. I attempted to go back to SP3 or 3.1 via the Vectorworks Updater application. After downloading the updates, closing the updater app, then opening the update packages, which opens the updater app again, the progress bar just sits at 0. No progress regressing to previous SP Quote Link to comment
Mickey Posted April 9 Share Posted April 9 On 3/27/2024 at 8:51 AM, Dave Donley said: Hello @dvdvarch if you are on Windows and you are seeing slow launch and performance (unusably slow to do anything) this may be a known issue related to the AI Visualizer and removing the GenerateImage plugin from the Plugins folder may help. There is another update coming to address that problem ASAP. I am experiencing tragically slow performance in general with 24 but particularly with sp4. So much so I've been exploring my system configuration using UserBenchmark. Although I have found some small tweaks my machine is still well within the specs of the "Highend" configuration and should be just fine. I will delete the generate plugins. Hopefully this helps as this slowness is really sucking out loud. Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted April 10 Vectorworks, Inc Employee Share Posted April 10 @Mickey If this is connected to the GenerateImage plugin, check for updates and run the latest Update which is 4.1. Update 4.1 fixes the problems with the AI Visualizer plugin. Quote Link to comment
