36 -
Everything posted by dvdvarch
Thank you Dave, for now I have solved going back to Update 3, thanks to the Italian distributor that has helped me. Since the main reason for me to update was to try the AI visualizer I will wait for the fix.
The same problem here. Any success in solving the problem? And also here: and here:
Service Patch 4 - Problem Launching/Does Nothing
dvdvarch replied to designit's question in Troubleshooting
The same problem here. Just installed update 4 and Vectorworks freezes after launch. Actually, it is not completely freezed, just very very very slow and unresponsive. Have you solved the problem? -
batch making hybrid symbol vectorworks with 2d and 3d components script
dvdvarch replied to dvdvarch's topic in Vectorscript
I see that nobody seems to have any suggestion. Does anybody know if this would be at least possible? Vectorscript or maybe marionette? thank you, -
Hi to everybody, I have a large symbol library to be created starting from obj or 3ds models. I have to do a plan and two sides views Do you think that would be possible to automatize the process? I know that it is possible to batch create symbols from a folder but then I would need to enter in each one and create the 2d components. I gave a look to scripting manuals but I am just starting to understand and I don't even know if this would be possible to do. I would like to make a script that would: Option A: batch create symbols from a folder and then create 2d components from 3d (but I would need probably to optimize meshes first outside Vectorworks to have clean results) Or Option B: batch create symbols from a folder with 3d models and then add 2d components taking them from another folder of dwg views that I have yet for each symbol. I made some research and I haven't found anything, this task sounds to me a (quite) common problem. Do you have any suggestion? Thank you!
I have just seen that you have posted the script yet! Its 2 a.m. ... thank you!
Hi Ben, I know that this is an old post, would you mind explaining how you set up the script to batch create materials and the add properties from worksheets? I was looking exactly for this, I would build a material list according to the products list I use in quantiy estimate takeoff. I intended to use materials the same way you do, putting in wall components, slabs etc Thank you!!
It works! Questions: How can I find in which object is a material used? Right-Click/select the object on drawing seems not working (probably because the data is referred to multiple objects). Yes, I use spaces a the moment the formula returns "0", actually the walls are *around* spaces, not inside, does the command work anyway? (bytheway I have tried to make a big object space to comprehend the objects and it seems not to work) Maybe this happens because rows are summarized. How to see one material instance per row? (but now I have tryied to make a material used in one space only and it still doesn't get the location) Thank you!! Thank you!!
Yes, I have found it, and it looks that they are insensible to criteria such as layer+class or whatever. I'm understanding that Material is a kind of an abstract entity, with no location, only objects has locations, but actually a construction work is a combination of material+manpower. Probably you are right. Yes, I found this too! I was breaking all my nice styled walls to insert compound materials with the feeling that I am fragmenting and breaking everything, having then to check wall orientation for each little piece (you have seen it, here in in Italy we deal with old historical walls). And, the final discover, I am struggling to understand how to link materials to a location (it doesn't look like I can use the "inside" function, correct?). Plus, a wall, usually, is inbetween two rooms... what I would need is a simple ( 🙂 ) table with a few columns: id, work/material, quantity, Room, Floor, Building; for everything, all formatted in the same way, project items, doors, windows, restoration of existing walls (that's the tricky part), paints, ceilings (?), floors... Tom, I'm spending a week to build a system in Vectorworks and I really don't want to make it traditionally with a calculator on my desk, an external quantity take off software nor Excel. I would like now to build a system that I can use in the future for this project changes and for other projects! Thank you!
Thank you very much Tom, from your attachement I understood how to properly format formulas for materials, now I am trying to make a worksheet to have all columns I need The only limit to this system looks like the necessity to manually make a lot of materials, I would like to be able to batch a long list of them (I have them on excel and filemaker database) p.s where are those formula list stored? are them available online?
Now I am trying to use data stored into materials, but I cannot find the material id formula. I see that it is used in the "materials by category" report, but how can I use that formula to populate a column? I cannot find "material id" in the fields that can be added to a report, see below: Again, I hope I have been able to explain what I mean, Thank you!
I got it, this could be a problem, it may happen often to improve work descriptions. Also, my work list is has actually 600 items, but I could divide them per type, i.e. constructions, demolitions, etc. but then, how to link area properties to each "true" line of the record format? should I make a criteria for each item? I would like to have a kind of a simple "tag" to attach to any item
You are right Pat, they could actually be hundreds. (in an ideal world they shoul also be linked to a databese with standard codes and descriptions). In your hipotesis how could I apply multiple works on the same wall? maybe I could do a record format like with, let's say, five or six items: work code1, work description1, work code2, work description2, work code3, ... would you mean something like that? what do you think? thank you! Yes! I forgot to flag "use material", measurment now works. thank you for checking it
Thank you Tom, I have attached a portion of the project. I have created two base materials and one compound material and I have applied it to m51 wall style. They were both selected, I have now turned on only "by area" since I need only areas. But still I don't see quantities in the reports I think that I have found the report you are talking about (they are two, actually, spreadsheet and database, not sure what is the difference). They are able to find the materials but still don't count quantities. Plus, it looks like a long process to manually exactly write material names in cells. I would need a report that massively reports all used materials and their quantities since the project is quite complex. thank you! QT setup.vwx
Good idea, Tom! I was thinking to add fake wall components, but they must have a thickness so it doesn't work. I am not used to material tool so it didn't come to my mind. What do you think would be the best way to apply these "non-material works" compuond materials to walls? to transform walls in non-styled wall and apply materials? To create a wall style+material for each work combination may multiply wall styles number. bytheway I have done a quick test and for now I couldn't get quantities, I am probably missing something thank you for your suggestions
Hi to all, In Vectorworks it is easy to count quantities of elements, such as, plaster, concrete, tiles... But sometimes (very often in my case), to estimate the cost of a project we need to count multiple works done on each component. I.e. in a renovation project I could have (I hope my english is clear enough, I couldn'f find the exact translation for such specific processes): - partial removal of old plaster and refilling of holes - consolidation of existing plaster - fixative anti dust primer - three coats o paint all done on the same wall I would like to have your advice and experiences in the best way to count non-material processes. I hope I have been able to explain clearly. Thank you!
problem with imported marionette object in new file .
dvdvarch replied to Ben3B's question in Troubleshooting
I just let you know that I have tryied to open your file, then double clicked on the object to see how it was built and it blocked Vectorworks with a series of infinite error windows. I had to force quit, now Vectorworks doesn't start anymore, it stops on splash screen. I think I will have to reinstall it! (and I hope to solve the problem)😶🌫️. What was in the file? (!) -
Data Visualization causes crash in a Project Shared file
dvdvarch replied to dvdvarch's question in Troubleshooting
It just happened the same problem (without crash) while trying to duplicate a design layer: it says that the object are owned by another user. And it lists my own computer (see screenshot, box is the name of my own PC) -
dvdvarch posted a question in Troubleshooting
Hi to everybody, we are using project sharing for a medium sized project: - three users (two of them administrators of the file) - wvxp file stored on a Dropbox shared folder It happens that trying to apply a data visualization to a viewport in a sheet layer, Vectorworks says: (approximate translation from italian) "it is not possible to perform this operation because the object is owned by another user": and it lists my own computer as it was another user's PC. And than Vectorworks crashes without notice. I think this "owned by another user" referred to myself has happened in other situations yet. But I have isolated this behavior with data visualization on vewports (maybe because viewports involve many layers altoghether, just guessing). Any of you have idea on how to avoid this? Is the Dropbox sharing correct with project sharing? Thank you very much! Davide -
Layer groups like classes
dvdvarch replied to dvdvarch's question in Wishlist - Feature and Content Requests
ahah yes 😀 I should switch to a 360° projector 😁 -
Ok, I will detach that too 🙂 in my three monitor cockpit I have on the left monitor: Resource browser and toolsets, center: the drawing alone, left (all detached): OIP, classes, layers, and now I will try to add views too -
Yes, I was thinking exactly to the same idea yesterday mmh, I will try, it looks quite a click-rich path 🙂
