Leandrovsk Posted February 5 Share Posted February 5 When I have a wall that is on the facade, it is on top of the slab, so on the facade there will be a line, which in real life would be covered and would not appear. How do I make this line not appear in the vectorworks model? Quote Link to comment
Tom W. Posted February 5 Share Posted February 5 3 hours ago, Leandrovsk said: which in real life would be covered If in real life the wall will cover the edge of the floor structure then this is how you should model it. The wall finish component should extend downwards to cover the edge of the Slab + the Slab should be set back accordingly. Bit hard to explain further without seeing exactly what you're doing. Quote Link to comment
zoomer Posted February 5 Share Posted February 5 As Tom said. But when the unwanted lines still appear, it is usually caused by a slight inaccuracy of Wall positions, not exactly matching. 1 Quote Link to comment
Leandrovsk Posted February 5 Author Share Posted February 5 Right. I'll send you some pictures, I've put a (yellow) cladding on the wall, so it should go down to the front of the structure. But as I understand it, it's the configuration of the slab that defines how far the wall goes. How do I make it so that only this component of the wall goes down to the front of the slab? Quote Link to comment
Tom W. Posted February 5 Share Posted February 5 8 minutes ago, Leandrovsk said: Right. I'll send you some pictures, I've put a (yellow) cladding on the wall, so it should go down to the front of the structure. But as I understand it, it's the configuration of the slab that defines how far the wall goes. How do I make it so that only this component of the wall goes down to the front of the slab? Edit the Wall components + add a bottom offset to the cladding component (see 'Components...' button in OIP to do it on a Wall by Wall basis or edit the Wall Style to have it affect all instances of the Wall). Slabs can Auto-Bounded or Manual. If it is Auto-Bounded it will automatically clip the Walls based on the part of the Wall the Slab component/s are auto-bound to in the Edge Offset settings. If it is Manual, you can treat each edge separately + set offsets for each of the components one by one but then you need to do the same with the bottom (or top) offsets for the Wall components. But this way you have a lot more control. A Slab will be auto-bounded if you create it using Picked Wall Mode or Inner Boundary Mode or you can do it retrospectively using 'Pick Boundary...' in the Bounding settings in the OIP. Quote Link to comment
Leandrovsk Posted February 5 Author Share Posted February 5 Great! The slab is finishing on the outside, that's right. But the external component of the wall is still not coming down and passing in front of the slab, even with the offset at the bottom... Quote Link to comment
line-weight Posted February 5 Share Posted February 5 Is it because you are editing the wall style, rather than that wall object specifically? Quote Link to comment
Leandrovsk Posted February 5 Author Share Posted February 5 39 minutes ago, line-weight said: Is it because you are editing the wall style, rather than that wall object specifically? I don't know, maybe that's it. Anyway, I'm working with wall styles, trying to keep all the elements with styles. Quote Link to comment
Leandrovsk Posted February 5 Author Share Posted February 5 You were right, when I turn it into a wall with no style it works. But I don't know if it's very productive to make walls without a style... 😕 Quote Link to comment
line-weight Posted February 5 Share Posted February 5 It can still be a wall with a style - but you can adjust that bottom offset for that one instance of the wall style. You do this using the "components" button in the object info panel for that particular wall object, rather than editing it in the wall style. Do you want all instances of that wall style to have that same offset of the outer component? Quote Link to comment
line-weight Posted February 5 Share Posted February 5 ( Maybe someone else can explain why editing the component offset in the wall style settings has no effect. I realise that actually I am not entirely clear how the wall style and instance settings interact. For most "styles", you can choose for each setting, whether it's determined per style or per instance. But in wall settings you aren't offered this choice. ) 1 Quote Link to comment
Leandrovsk Posted February 5 Author Share Posted February 5 8 minutes ago, line-weight said: It can still be a wall with a style - but you can adjust that bottom offset for that one instance of the wall style. You do this using the "components" button in the object info panel for that particular wall object, rather than editing it in the wall style. Do you want all instances of that wall style to have that same offset of the outer component? Perfect! I hadn't seen that even with the name of the component in gray it could be edited, now that you said it I saw the button below! Wonderful! Just one more question, if I edit my walls, individually, is there a way for it to go back to the original style, wiping out all those changes I made and just keeping the initial style? Quote Link to comment
Leandrovsk Posted February 5 Author Share Posted February 5 12 minutes ago, line-weight said: ( Maybe someone else can explain why editing the component offset in the wall style settings has no effect. I realise that actually I am not entirely clear how the wall style and instance settings interact. For most "styles", you can choose for each setting, whether it's determined per style or per instance. But in wall settings you aren't offered this choice. ) I think I found out by accident here, you can't edit the style and update the wall, you have to draw it again... Quote Link to comment
line-weight Posted February 5 Share Posted February 5 13 minutes ago, Leandrovsk said: Perfect! I hadn't seen that even with the name of the component in gray it could be edited, now that you said it I saw the button below! Wonderful! You can see that it will let you edit the "top" and "bottom" (offset) columns, but it won't for example let you edit the thickness of the component. To do that, you have to either change it in the style, or make that wall unstyled. Quote Link to comment
line-weight Posted February 5 Share Posted February 5 17 minutes ago, Leandrovsk said: Just one more question, if I edit my walls, individually, is there a way for it to go back to the original style, wiping out all those changes I made and just keeping the initial style? Good question - I think the answer is no. I think you have to go and change all those offsets back to zero manually. However, I think you can bulk-select several wall objects and do this. Quote Link to comment
Pat Stanford Posted February 5 Share Posted February 5 Change the wall to a different Style and then change it back? Quote Link to comment
line-weight Posted February 5 Share Posted February 5 Ok, I've had a bit of a long day and may be missing something, but does setting those "top" and "bottom" component offsets in a wall style actually do anything? Because it looks to me like it has no effect. If it has no effect they shouldn't be there, or they should be greyed out. Quote Link to comment
Leandrovsk Posted February 5 Author Share Posted February 5 2 minutes ago, line-weight said: Ok, I've had a bit of a long day and may be missing something, but does setting those "top" and "bottom" component offsets in a wall style actually do anything? Because it looks to me like it has no effect. If it has no effect they shouldn't be there, or they should be greyed out. It looks like it does, but you have to draw the wall again. Quote Link to comment
Leandrovsk Posted February 5 Author Share Posted February 5 7 minutes ago, Pat Stanford said: Change the wall to a different Style and then change it back? It's not ideal, but it works. I think there should be a button like there is for "Make All Attributes by Class" Quote Link to comment
Tom W. Posted February 5 Share Posted February 5 39 minutes ago, line-weight said: ( Maybe someone else can explain why editing the component offset in the wall style settings has no effect. I realise that actually I am not entirely clear how the wall style and instance settings interact. For most "styles", you can choose for each setting, whether it's determined per style or per instance. But in wall settings you aren't offered this choice. ) You need to have 'Replace heights' enabled in the Wall Replacement dialog. Walls, Slabs, etc are different to other ('true'?) styles in that the instances are replaced rather than edited directly. 2 Quote Link to comment
zoomer Posted February 5 Share Posted February 5 5 minutes ago, Leandrovsk said: It looks like it does, but you have to draw the wall again. Not really. Usually you will work with PIO Styles as much as possible. When you change a Wall Style, all inserted Walls will follow (*). You will want to only overwrite special Wall situations in OIP There are just two caveats : - when saving you Wall Style changes, there is an option to only change Wall Heights that were not overwritten. (One of the best VW features as it allows such special cases without the need of Style duplicates) I think it is activated by default - which is a good thing. - When you graphically edited Wall Peaks by dragging. These delta offsets will stay additional on top of Style height changes and can be quite confusing ! (use "delete Wall peaks" to get back control) I use Stories+Levels intensively. So I also use Story Levels to bind my Walls heights and Wall Components heights to Levels. So e.g. my overall Wall is set to Wall bottom base = "top of structural Slab", my, Wall top is "bottom of structural Slab -Story above". Same for my structural Wall Component(s). But my outer Insulation Package Components will use same top but bottom will be "bottom of structural Slab". (Inner finishes tops may start at "top of Finish Floor) 1 Quote Link to comment
line-weight Posted February 5 Share Posted February 5 42 minutes ago, Tom W. said: You need to have 'Replace heights' enabled in the Wall Replacement dialog. Walls, Slabs, etc are different to other ('true'?) styles in that the instances are replaced rather than edited directly. Oh yeah. Of course. Quote Link to comment
line-weight Posted February 5 Share Posted February 5 Also ... I was changing wall style settings, and then drawing new walls to see if they took on the new properties, which they didn't. But the reason this was happening is that instead of drawing a new wall with the wall tool, I was right-clicking on an existing one and choosing "create similar object" and making the assumption that it would create a new wall in the chosen style rather than one with all the instance-specific settings. 1 Quote Link to comment
Tom W. Posted February 5 Share Posted February 5 I can still never get my head around when to use + when not to use 'Only replace default heights' though. No matter how many times I read this it always goes over my head: Is anyone else clearer? 1 Quote Link to comment
