  • 3
Make the "insert location" indicator (in component buildups) less confusing
line-weight
12 answers to this question
OMG this is crazy!! I never use the Wall Insert Location settings - I always set the insert location in the PIO options - so had no idea this was the case! Surely this must be a mistake? The 'Insert Loc' arrow in the example below clearly indicates the PIO will insert aligned with the left edge of Wall component 3. Why would the wall diagram above + the insert loc symbol below be oriented in different directions??!
@Matt Panzer? Surely this isn't how it's meant to be?
Yes it's always been there for Slabs, Roofs + Hardscapes but only recently for Walls (I think) - since Wall Closures in VW2022 perhaps? My screenshot was from the 'Edit Wall Style' dialog. I assumed your screenshots were the same.
The thing is for slabs/roofs/hardscapes it's pretty straightforward to tell that the arrow is pointing up or down. For walls it's a case of left or right, for which we rely on the diagram above with the little arrow giving the wall's direction + therefore which side is left + which side is right. That's why it's so crazy the arrow in the component list is pointing in the opposite direction (or rather has the opposite effect in the model).
This is as designed.  The line of the icon is the component and the arrow points to the face (or centerline) for the insert location.  As @line-weight noted, the data for the slab works the same way to indicate top or bottom.
Ah ok sorry I see. I realise now I actually find the slab etc icon confusing too but there I can check whether it says 'top of component' or 'bottom of component' to confirm what it is I'm looking at. Which is precisely what @line-weight says in his post. Ok. got it!
The thing is that a component has thickness, so it should really be represented with a rectangle not a line.
In conventional architectural drawings, you'd not generally use that symbol to point at just a line, you'd use it to point at the top or bottom of a slab, which is a thing with thickness, and having the arrow point up or down helps with legibility (quickly understand that something refers to a ceiling level, say).
If a symbol like that is use on a line, like for a reference datum level, then it doesn't technically matter whether it's pointing up or down... because a line has no thickness.
  • Like 3
Definitely! This would make it crystal clear it's pointing to the outside face + not the inside edge which is what it currently looks like, even for slabs etc.
  • Like 3
Is there any good reason not to change that design, to make everyone's life a bit easier?
Edited by line-weight
