CKeng Posted June 1, 2023 Share Posted June 1, 2023 Hi, I'm working on Spotlight Vectorworks and some of the lights that I can't find in the resource manager like Patt 743 1k Fresnel etc. How should I create one by myself or where can I find some resources for that? Quote Link to comment
markdd Posted June 1, 2023 Share Posted June 1, 2023 I have some of the old Strand Symbols. What do you need? 1 Quote Link to comment
CKeng Posted June 1, 2023 Author Share Posted June 1, 2023 Do you have strand SLs and fresnels? I'm not sure if they have PCs but honestly everything is appreciated! Quote Link to comment
Vectorworks, Inc Employee JustinVH Posted June 1, 2023 Vectorworks, Inc Employee Share Posted June 1, 2023 https://app-help.vectorworks.net/2023/eng/VW2023_Guide/LightingDesign2/Workflow_Creating_lighting_device_symbol_definitions.htm?rhsearch=lighting device&rhhlterm=lighting light lights device devices There are also videos on Vectorworks university on how to create lighting devices. Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted June 4, 2023 Vectorworks, Inc Employee Share Posted June 4, 2023 Hello, If you want some shapes please find them in this Vectorworks file that I enclose. They're 2D only symbols, no record attached. Just do a Modify>Convert>Convert to Group to get the geometry. Then follow Justin's advice on turning them into Lighting Devices. You should also check out https://www.fieldtemplate.com Cheers, Peter Old symbols.vwx 1 Quote Link to comment
CKeng Posted June 5, 2023 Author Share Posted June 5, 2023 On 6/4/2023 at 1:25 AM, Peter Neufeld. said: Hello, If you want some shapes please find them in this Vectorworks file that I enclose. They're 2D only symbols, no record attached. Just do a Modify>Convert>Convert to Group to get the geometry. Then follow Justin's advice on turning them into Lighting Devices. You should also check out https://www.fieldtemplate.com Cheers, Peter Old symbols.vwx Hi Peter, Thanks for your advice and help! I would love to open the file and have a look but I'm not sure why I can't open it. My Vectorworks is still in 2021 so maybe your version is newer? Cheers, Cheng Quote Link to comment
markdd Posted June 5, 2023 Share Posted June 5, 2023 Try these for size. It is quite a few years since I used most of these but you may find them useful.... These have been back saved to 2021. The Record formats are very current, so you will need to allow your 2021 file to overwrite the Record formats as you import them. Otherwise, they should be ok. Old Strand Symbols v2021.vwx 1 Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted June 6, 2023 Vectorworks, Inc Employee Share Posted June 6, 2023 Ah I thought so! Mark's symbols are much much better than the 2D only ones I posted. Lovely. Brings back memories of the great and some not so great (ie more recent) Strand offerings! Stick with Mark's generous offering. The 3D is wonderful. Cheers, Peter 1 Quote Link to comment
MBurke Posted August 18, 2023 Share Posted August 18, 2023 Hi all, Could I be so bold as to ask for a v2020 version of the Old Strand Symbols? Thank you in advance! Cheers, Matt Quote Link to comment
MrTemplate Posted August 18, 2023 Share Posted August 18, 2023 can you be more precise? like a specific fixture or range? strand was a prety prolific manufacturer. Quote Link to comment
MBurke Posted August 21, 2023 Share Posted August 21, 2023 Hi MrTemplate, I was just referring to the file shared by markdd above, titled "Old Strand Symbols v2021.vwx" Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted August 22, 2023 Vectorworks, Inc Employee Share Posted August 22, 2023 Here you go. Cheers, Peter Old Strand Symbols v2020.vwx.zip Quote Link to comment
MBurke Posted August 22, 2023 Share Posted August 22, 2023 Legend, thank you kindly! Quote Link to comment
Jake Wilson Posted April 5 Share Posted April 5 On 6/5/2023 at 12:58 PM, markdd said: Try these for size. It is quite a few years since I used most of these but you may find them useful.... These have been back saved to 2021. The Record formats are very current, so you will need to allow your 2021 file to overwrite the Record formats as you import them. Otherwise, they should be ok. Old Strand Symbols v2021.vwx 7.33 MB · 29 downloads Hi, I tried to open the file you shared in VW2024 design suite and all I see is an empty design layer. I checked the classes and everything is visible Layer options are Show/Snap others The OIP data tab shows some light information(plug type and temp) I downloaded and opened like any other file and got the this file was created in an older blah blah blah Not sure what I'm missing here Quote Link to comment
markdd Posted April 6 Share Posted April 6 3 hours ago, Jake Wilson said: Hi, I tried to open the file you shared in VW2024 design suite and all I see is an empty design layer. I checked the classes and everything is visible Layer options are Show/Snap others The OIP data tab shows some light information(plug type and temp) I downloaded and opened like any other file and got the this file was created in an older blah blah blah Not sure what I'm missing here Have you looked in the resource manager? The symbols should all be there. 2 Quote Link to comment
