Hi all,
I have a simple question but I can't fully understand it. I used to draft on Autocad for lighting plans but recently I started to use Vectorworks. I'm not so sure about what scale Is hould be choosing. Most of the time, I will have a PDF plan from venues in 1:50. Should I set the layer scale in 1:50 to match it? If I what to add lines or shapes in this layer, do I have to recalculate the dimensions? Or I just confuse myself here?
I suppose that it will be better to use the same scale in each layer, so I just want to make sure everything is correct.
Thanks so much!
