cberg Posted March 13, 2023 Share Posted March 13, 2023 (edited) I've had this issue this on several jobs now. I am working on a plan that is somewhat far away the drawing origin 5000' [1,500m]. I made a bunch of spaces, and after working in the file a bit, the locus of the space shifted very far away from the center of the space. Is there any way to move this point so that it falls within the space boundary? How did this point get so far away from the center of the space? Moving the space closer to the page center does not seem to fix. Using data tags becomes problematic when the space gets like this, especially in Sheet Layers See the attached file to see what I am referring to. It's sort of hard to explain. Space.vwx Edited March 13, 2023 by cberg Quote Link to comment
cberg Posted March 14, 2023 Author Share Posted March 14, 2023 (edited) There must be some sort of bug in the space tool. I will submit In some of these spaces, loci are present. In others, they are invisible. If I activate the space settings of a space with a locus, it will appear. If I create a similar space without a locus present, it will not appear. If I convert a rectangle or polygon into a space in the AEC "Create Object From Shapes" menu, the loci disappear. I looked through the space tag settings to see whether you can turn the locus on or off, and there do not appear to be any controls for this. Perhaps this internal locus is a hidden feature of the space, that somehow becomes visible. I modify the space boundaries a lot using clip/add surface/split tools, etc. When space locus is far away from the center of the space, data tags create a big pre-selection rectangle, which can misidentify the space. The only way to fix this problem is to re-draw the spaces. Space 2.vwx Edited March 14, 2023 by cberg 1 Quote Link to comment
Tom W. Posted March 18, 2023 Share Posted March 18, 2023 I've had weird loci behaviour with Spaces too... 2 Quote Link to comment
Patrick Fritsch Posted March 30, 2023 Share Posted March 30, 2023 Having same locus issue with spaces...annoying! Quote Link to comment
cberg Posted March 30, 2023 Author Share Posted March 30, 2023 It was submitted into bug submit a few weeks ago, but I never got a response of any sort. My only fix was to remake the spaces that get corrupted. Quote Link to comment
AChekir Posted December 8, 2023 Share Posted December 8, 2023 (edited) The 2D locus is used by the Space link tool as the insertion point to link spaces together If your locus is far away from the space object, no need to recreate the space. Edit the perimeter of the space and bring the polygon to the locus. On exit the edit mode, you will find the locus inside the space. Then you only have to replace the space to its position Edited December 8, 2023 by AChekir 1 Quote Link to comment
Gaëtan R. Posted December 10, 2023 Share Posted December 10, 2023 (edited) I found that the fact that this 2D locus appears is linked to the setting “Graphics Attributes” > “2D Boundary”. When the settings of this 2D boundary is set “by class” the 2D locus appears. If all thoses settings are set manually, the 2D locus disappears. This bug does not appear in 2024, hope that 2023 will be corrected in SP8 ! Edited December 10, 2023 by GatRed 2 Quote Link to comment
