Rotate vs Mirror or ¿ is there an alternate to Mirror for Extrudes, Symbols etcetera ?
Being forced to recreate items and / or take up an alternate workflow - ie: do NOT mirror Extrudes, Symbols etcetera anymore !
When possible duplicate and rotate vs mirror. Or (UGH!) take Extrudes / Symbols apart and recreate in the new design from the fundamental geometry - possibly in several iterations.
Some of this is based on editing old or inherited Hybrid Symbols (Made from extrudes...) that do very strange things based on where and how the original was created.
Combine the Component Edit Mode complications with Paste and Paste in Place that do NOT behave as expected, and VW/RW creates one aggravating situation.
¿Is there a way to Mirror in VW/RW (... a preference setting?) that keeps these specific items in the Mirrored location, vs going back to edit in the original "zero-zero" location of creation ?)
Thanks to Andy B comments (BUG), we have stopped editing Extrudes, Symbols etcetera on the drawing and attempt to only edit such items from within the Resource Manager.
This eliminates one aggravation: the Rotated Plan effect. (File is a single Design Layer).
Where an extrude is created, is where it will go back to when you double click to edit.
The item remains on the Screen in its current Screen location (Top/Plan), only the page moves (...& rotates) to the X-Y location of creation. This requires the use of 3D Move, for example, vs 2D move. Even though the orientation / indication / notation would indicate otherwise.
Same thing for Symbols (?) - It is a double whammy here if the Symbol is created from an Extrude.
Workflow Best Bet" "zero-zero" should always be the location of creation.
Elite Exhibits
Question:
Assumptions:
Question: ¿ How does one eliminate the Rotated Plan Effect ? (Short of hitting Command-A, Command 5, Command 4 every time you edit a ...)
(VW/RW Designer 2020 - iMac Pro )
Suggestions are always appreciated !
Peter
6 answers to this question
