I'd like a more efficient way of looking orthogonally at a surface of my model that isn't aligned to one of the cardinal views. We use 'Set Working Plane' and 'Look at Working Plane' quite a bit—because our buildings are not square boxes—but it's a convoluted process.
Instead, one of the following options would be better, in order of personal preference:
A new contextual menu item: Set and View Working Plane. With the Selection Tool active the user would simply right-click on any surface, select this option and it would set the Working Plane and take the user to an orthogonal view of the Working Plane.*
A new 3D Modelling tool: Set and View Working Plane. Using this tool would not only set the Working Plane but also take the user to an orthogonal view of the Working Plane.*
* It should always be orthogonal. I never want to look at a Working Plane in perspective.
The first option is by far the most efficient, with two clicks and no need to move the cursor to a tool palette. The second option would have the benefit of pre-selection (as the current Set Working Plane tool works), and would still be relatively efficient with 3-clicks and one move to a tool palette.
The current UI for this is a convoluted 5-click process:
Move cursor to and select 3D Modelling toolset
Select Working Plane tool
Click on relevant face in model
Select View menu
Choose Look at Working Plane (for which there is no keyboard shortcut)
If you're in perspective it will also require a 6th and 7th click to change to orthogonal
Christiaan
Select View menu
Edited by ChristiaanLink to comment
8 answers to this question
