Neil Barman
Vectorworks, Inc Employee
    709
Posts posted by Neil Barman
  1. 9 hours ago, JMR said:
    ^ That does not always seem to be the case, I guess some space objects or slabs confuse the selection..
    I can imagine that arriving at the right Design Layer could be tricky depending on where the click is targeting, when aiming for a Slab or Space Object, if those objects are underneath other objects that are on different Design Layers. If right-clicking on a SLVP, I do believe the “Edit Design Layer” command will target the DL of the topmost object. So, if targeting the edge of a slab that is coincident with a Wall’s edge, the Wall’s DL would win.
    Out of curiosity, what are the objects that are “interfering” with targeting the Slab or Space Object’s DL
  2. @CharlesJ You can find your signature under the avatar icon in the top right corner > Account settings (in the menu that drops down) > Signature (on the left side tabs). Currently your signature reads that you’re using Mac OS 10.10 and Vectorworks 2015.
    If you can’t see your own signature, or even my signature, then perhaps the option to view signatures has been switched off for you. The option to view signatures can also be found in your Account Settings > Signature section.
    • Like 1
  3. 21 hours ago, JMR said:
    Often SLVP's display several designs layers. Currently, the right-mouse-click option "edit design layer" picks one the design layers, according to some unclear logic. It's impossible or difficult to choose a certain design layer for editing using this method.
    If you right-click on a particular object shown in the SLVP, then select “Edit Design Layer” from the contextual menu that appears, the Design Layer that you will be taken directly to is the Design Layer where that object is located.
    • Like 2
  4. We saw this once as well with a client who was using Google Drive. Once the PS file was fixed, with the surperb help of @Tolu, the Project file was allowed to perform better by being on Dropbox instead (possibly due Dropbox’s LAN sync ability as the users were usually on the same LAN.)
  5. @John Vancouver I too have seen the kind of lag you describe sometimes when there have been other Bluetooth/wireless devices nearby. I’ve experienced this mostly with other Bluetooth mice, but occasionally with Apple’s Magic Mouse. When I do see the issue, it’s not isolated to Vectorworks, so it’s pretty clear that it’s a more of a system or BT issue.
  6. @ckudi Hearing that your Vectorworks files are stored on a server makes me wonder... Do you have the same issue when working on a file that is stored locally on your own computer? If you haven’t tested this yet, please do.
    Having a server, a network, and network traffic, as part of the issue introduces so many variables (that are beyond the scope of Vectorworks) that it’s often best to troubleshoot using locally stored files to remove those variables. Since you mention that you had similar problems in v2017 I am especially suspicious that the server or network may be involved in the problem you are seeing.
    Also, have you received permission to share a file here yet?
  7. On 2018-01-24 at 7:59 AM, JimW said:
    They have not narrowed down the cause yet, but many of the palettes are in the process of being rebuilt/refactored (to fix things like the Snapping palette behaving differently than all other palettes for instance) and that may all have to be completed before this stops happening.
    If you’re still seeing the issue in SP3, then what @JimW described above hasn’t occurred yet. But if their software engineers are aware of the issue then they are working on it. Sometimes fixes require more diagnosis and repair work than can be done from one Service Pack to the next.
    As a side note, you can always check the list of what’s been fixed/adjusted for each Service Pack. On the individual SP webpage, look for the line “To learn more about the fixes and improvements in the 2018 SP3 updater, please visit this page” as it has a link to the list.
  8. @ckudi I’m sorry to hear that you’re having this experience as well. I haven’t heard of this particular issue either, so I too don’t think this a general problem... which means there must be a cause. Now it’s just a matter of finding the cause. Patience and perseverance will typically get you there. (Switching to another application will just get you THAT applications issues.)
    I’m curious...
    - Are you seeing the issue with ALL files or just certain files? Does it occur even with brand new blank files not made from a template?
    - Are you working on files that are stored on a server or are they stored on your computer?
    - Are all of your graphics drivers up to date, and are you 100% sure of this? (In some cases, drivers on Windows machines may not update with the various automatic updates, so driver updates should be checked for and done manually from the graphics card manufacturer’s website.)
    - Can you post a file in which you’re seeing the issue?
    Thanks.
  9. Oops, sorry about that... Having sigs switched off for a while now I forgot about them! I'd better switch those back on.
    I am thinking about getting one, yes, and I have had a client considering it too. I got to demo one at the Design Summit in Baltimore and it felt quite good.
  10. On 2017-12-15 at 7:55 AM, JimW said:
    Semi related to that, any thoughts on some changes I'm working on?
    1) Reorganized the user pane to be off to the left...
    2) Re-enabled the highlighted posts...
    3) The reactions at the bottom right of a post with the up and down arrows will be replaced by something else that slides out when clicked on and has a range of items to pick from...
    I like all three of these proposed changes!
    #1 does make the posts subtly but very nicely easier to read in sequence.
    #2 will be great at making it even more clear that Vectorworks Inc team members are active on the Forum, which I think is a very important aspect of this Community.
    #3 I'm especially keen to see this. There is some really great information here and and being to "compliment" it and its author will help to highlight it for others. (Similarly, being able to tag non-helpful information will also help improve content. If a post gets enough "down-votes" will it be hidden from the thread by default, unless clicked?)
  11. Thanks some big news from this year @JimW! Congratulations!
    As I know many of the people of whom you speak, I agree that you are very fortunate to have them as part of your community and family. (I feel the same – I just wish you all were a tad closer.) The Vectorworks team (you included!) are a pretty amazing, versatile, friendly and brilliant bunch. I can honestly say that the people at Vectorworks are a major part of the software and they make it a pleasure to use, support and teach the software.
    Thank you once again for guiding this forum to its new incarnation and making it truly unique and valuable resource for all of us.
    All the best of the holidays and the coming new year,
    -Neil
  12. Hi Andy,
    I understand that your colleagues have advised you to stay clear of referencing in the situation you describe, however I have done this a number of times with success. In fact, for one office I worked with recently, I have actually taken an entire project that was (before i arrived) "broken" because it was made with unit plans as symbols (as you are trying to do) and I made the file work properly, as the office had wanted it to work, using referencing. (This particular example was done within one file, however the other example I mentioned in our previous, direct emails had 4 files involved - 1 individual file for each of the 3 unit plans and then one Master file that brought everything and the sloped site together. This was in the days prior to Project Sharing and the units were in separate files so that different people could work on them at the same time.)
    Your colleagues may have had a negative experience at some point, but I would imagine that something may have been done incorrectly in the referencing process. When done correctly, which isn't difficult, referencing works very well for what you are wanting to do.
    About #1 - I do understand what you were doing, however the objects that you were putting into the unit plan symbols do not like being in symbols. The referencing technique I explained works great. Using Symbols to do what you are trying to achieve will likely cause you issues.
    About #2 - As I had requested via our tech support conversation, please do send me (or post here) the actual Vectorworks file you are using. I would like to investigate, but I can't actually examine the use of those objects adequately via the video alone. It appears to be something of a non-standard use of the tool, but having the Vectorworks file in hand will help tremendously.
    Thanks,
    -Neil
