Greg Miller
17 -
Reputation
5 NeutralPersonal Information
Occupation
Architect
Location
Boulder Creek, CA
Recent Profile Visitors
Very weak graphic design of tool icons
Greg Miller replied to KenAB94662's topic in General Discussion
Agree on the anemic icon design on the palettes. Taking way too long to learn the new icons and distinguish between them. Maybe old eyes?? -
Still trying this myself. No joy.
vectorworks 2023 startup freezing on loading cineware
Greg Miller replied to sLMA's question in Troubleshooting
Yep, this problem starting cropping up for me in the last couple of weeks. Have not changed anything on computer. Running Monterrey and SP4. Starting to happen more often than not. Restarting VW, restarting computer, does not work. Removing Cineware folder does. But, then you have rendering issues, of course. -
Did a quick test here is 2023. It looks like the offset is working. In this example, I have 3 layers to the roof style and I offset the inner "rafters" layer to align with the inner wall core (using the Create Roof tool). Could have been any of the choices. But, it is aligning OK on the eaves AND the rakes. However, I had to do it manually because if you did it automatically using the bounded walls, it got confused when one side of the simple rectangular layout of exterior walls had a non-continuous wall. It ended up offsetting OK on all but that one side. Well, most of the time, one is going to have conditions like that. So, I switched to manually offsetting and it worked. The problem now is that I cannot have my rake with a different overhang than my eave, which is also a VERY common condition. So, halfway there? Seems like a simple addition for Gable conditions to add. Next request, and this may be more uncommon, but in my area, we are often using thinner eave framing than what is needed on the interior of the roof (where thick insulation is needed). So, in those cases, being able to adjust the thickness of the roof component (from the top edge) would be perfect. Curious if this would be useful for anyone else. Roof forms are almost always more complicated than someone in the application development team thinks and this tool needs to be more complex too. Because of that reality, I typically need to use the Roof Face tool instead of the Create Roof tool, so I will be checking that out next. Still, progress is encouraging. Did
Setting Default Linetype
Greg Miller replied to JMSarch's question in Wishlist - Feature and Content Requests
Yeah, did not work for me. I get the Fence line type every time I change from solid. PLUS, with 2022, I get to wait quite some time for the line types pop up to show. Not sure what that became a thing....spinning beachball and everything. Same with most attribute popups. 2017 iMac, 40 gb, Big Sur. -
Still an issue in 2022, believe it or not.
Crash after editing lights VW2021 / VW2022
Greg Miller replied to bjoerka's question in Troubleshooting
Still happening to me every time: VW2022 SP2 build 619242 MacOS 11.6 iMac (Retina 5K, 27-inch, 2017); 3.8 GHz Quad-Core Intel Core i5; 40 GB 2400 MHz DDR4; Radeon Pro 580 8 GB Seems to be tied to adjusting the brightness. Adding the light works fine. I will try updating VW again to make sure I have latest. But that build should still have the fix from previous builds. -
Yep. Happening to me about 50% of the time I go to one of my Sheet Layers. The Title Block seems to still be there, if you click on a part of it. If I double-click, open and close the subsequent dialog box, the block appears again. Keeps happening. Multiple files, VW2020 SP4. Usually, when it happens, all of my sheets are affected. So far, it still shows up when I Publish. Amazing this is going on for 6 years. What the hec??
Window sills in PIO do not work properly
Greg Miller replied to billtheia's topic in General Discussion
Wow. 9 years later, windows are still modeled with the sill below a bottom "jamb". -
Workspace window sizing not being stored
Greg Miller replied to jweston's question in Troubleshooting
FYI, more than two years later and two new versions of the software, this is still the same bug as always. Saving palette positions does not work. Two monitors confuses Vectorworks. Every time I open VW, I have to manually relocate all of the palettes. Any crash of VW will reset the palettes back to default, bringing up saved workspace does nothing to fix it in either case. -
Did this ever get fixed. I am still having the exact same issue with simple gable roof forms in 2020.
Would love to hear from VW on this. I assume a plugin is in the works, but it would be great to know how long we will have to wait.
Are there advantages or disadvantages to .obj support for 3D printing as opposed to .stl? I will be printing to a MakerBot Replicator next month. Seems both formats are OK, but I am starting to research how to get from Vectorworks to either of those formats.
First thing I checked was the Mode bar. I have since done all options on the Mode bar just for good measure. I have also discovered that option-dragging does not work anymore either (should give me a duplicate object). So, I have tried a different keyboard too. Nothing.
All of the sudden, I cannot select more than one object by using the shift key. Played with class and layer options, restarted Vectorworks, tried older files that were fine, played with selection tool options. Nothing works. I can select with a marquee, but then cannot unselect single objects from groups of selected objects either. The option-select is not working either. Yikes! What is going on here?
